Home » Archived » Buckminster » buckminster headless install
buckminster headless install [message #534413] Wed, 19 May 2010 01:44 Go to next message
Hi all
I have troubles installing buckminster headless.
As I am behind a proxy I cannot install on windows in commandline with following:
director -r http://download.eclipse.org/tools/buckminster/headless-3.5/ -d c:\buckminster_headless -p Buckminster -i org.eclipse.buckminster.cmdline.product
I get the message
19.05.2010 07:38:05 org.apache.commons.httpclient.HttpMethodDirector executeWithRetry
INFO: I/O exception (java.net.ConnectException) caught when processing request: Connection timed out: connect
INFO: Retrying request
How can I fix this problem?
So I have tested another way to install:
I have downloaded the file 'org.eclipse.buckminster.site.eclipse.headless_1.1.350.r1125 2.zip' and install from this file:
director.bat -r file://C:\org.eclipse.buckminster.site.eclipse.headless_1.1.350.r11252 -d c:\buckminster -p Buckminster -i org.eclipse.buckminster.cmdline.product
That was OK
So I tried to install required features. I tried
C:\buckminster>buckminster.bat install file://C:\buckminster_headless\org.eclipse.buckminster.site.eclipse.headless_1.1.350.r11252 org.eclipse.buckminster.core.headless.feature
but there was an error
No suitable feature/version found that matches org.eclipse.buckminster.core.headless.feature.feature.group
Can you help me to install buckminster headless and its required features correctly?
Any ideas?
best regards
Rainer
Re: buckminster headless install [message #534418 is a reply to message #534413] Wed, 19 May 2010 02:18 Go to previous messageGo to next message
I had the same problem here and tried to specify httpproxy values, but
p2 seems not to pick them up
news://news.eclipse.org:119/hscah4$1n3$1@build.eclipse.org
On 19.05.2010 07:44, rainer123@wolke7.net wrote:
> Hi all
> following:
> I get the message
> executeWithRetry
> executeWithRetry
> director.bat -r
> file://C:\org.eclipse.buckminster.site.eclipse.headless_1.1. 350.r11252
> That was OK
> file://C:\buckminster_headless\org.eclipse.buckminster.site. eclipse.headless_1.1.350.r11252
> features correctly?
> Any ideas?
> best regards
> Rainer
Re: buckminster headless install [message #657371 is a reply to message #534418] Wed, 02 March 2011 10:15 Go to previous messageGo to next message
Did anyone ever figure this out? I'm having the same problem and I've done everything I know to specify my proxy settings from passing them in to putting them into org.eclipse.core.net.prefs
Re: buckminster headless install [message #657516 is a reply to message #657371] Thu, 03 March 2011 01:51 Go to previous messageGo to next message
Hi Josh,
IIRC, 3.5 had a problem with this. In 3.6, Buckminster relies on the
platfrom which in turn relies on your environment settings. You should
probably try passing nothing at all and have no
org.eclipse.core.net.prefs. That works well for us when using Bucky
behind a proxy.
HTH,
Thomas Hallgren
Re: buckminster headless install [message #657624 is a reply to message #657516] Thu, 03 March 2011 08:57 Go to previous messageGo to next message
What I do is apply my proxy settings to the director install. So after unzipping director.zip, I do this in my install script:
# set up the proxy
cat > ${unzip_dir}/director/configuration/.settings/org.eclipse.co re.net.prefs <<'END_OF_CONFIG'
systemProxiesEnabled=false
org.eclipse.core.net.hasMigrated=true
proxyData/HTTPS/port=8080
proxyData/HTTP/host=wwwcache.xxx.com
nonProxiedHosts=trac.xxx.com|localhost|127.0.0.1
proxyData/HTTP/hasAuth=false
proxyData/HTTP/port=8080
eclipse.preferences.version=1
proxyData/HTTPS/hasAuth=false
proxyData/HTTPS/host=wwwcache.xxx.com
END_OF_CONFIG
That's for Linux, obviously, but there should be an equivalent for Windows.
However, given Thomas' advice it looks like this isn't needed.
Matthew Webber
Re: buckminster headless install [message #657747 is a reply to message #657624] Thu, 03 March 2011 15:06 Go to previous messageGo to next message
Matthew Webber wrote on Thu, 03 March 2011 08:57
# set up the proxy
END_OF_CONFIG
Matthew Webber
This worked and helped immensely! Thank you!! I definitely needed to specify this somewhere as the directory was not picking up my environment variables on linux as Thomas suggested.
Re: buckminster headless install [message #718022 is a reply to message #657516] Tue, 23 August 2011 00:06 Go to previous message
I am trying this on solaris with 3.6, but no success. Also tried the .settings approach. No success. Which environment variables are mapped?
Previous Topic:Basedir for Feature incorrect
Next Topic:Re: getting shiro with buckminster
Current Time: Wed Jul 23 08:00:51 EDT 2025
Powered by FUDForum. Page generated in 0.69436 seconds
