Home » Eclipse Projects » Standard Widget Toolkit (SWT) » How to repair canvas?
How to repair canvas? [message #534089] Mon, 17 May 2010 20:35 Go to next message
I have a Canvas that is partially obscured when a combo box above it is opened. After the combo box is closed, the part of the Canvas that was obscured appears blank. How can this situation be handled without having to install listeners on any control that could obscure the canvas?
Re: How to repair canvas? [message #534136 is a reply to message #534089] Tue, 18 May 2010 04:19 Go to previous messageGo to next message
You can refresh the canvas by calling redraw and update....
but if you want to update that specific area then you need to know the exact bounds and use redraw(int x, int y, int width, int height, boolean all)
but the question is why is it not repainting itself when the combo collapses?
How are you painting the canvas??
Re: How to repair canvas? [message #534313 is a reply to message #534136] Tue, 18 May 2010 11:42 Go to previous messageGo to next message
vijay wrote on Tue, 18 May 2010 04:19
[...] but the question is why is it not repainting itself when the combo collapses?
The canvas repaints itself after being resized or obscured by another window, but not in the case mentioned above.
Here's how the canvas is painted:
Canvas canvas = new Canvas(composite, SWT.BORDER);
canvas.addPaintListener(new PaintListener() {
  public void paintControl(PaintEvent e) {
    // draw on e.gc...
Re: How to repair canvas? [message #534321 is a reply to message #534313] Tue, 18 May 2010 12:13 Go to previous messageGo to next message
How come this snippet works
or can you reproduce it in this
package org.eclipse.gef.examples.shapes;
//Send questions, comments, bug reports, etc. to the authors:
//Rob Warner (rwarner@interspatial.com)
//Robert Harris (rbrt_harris@yahoo.com)
import org.eclipse.swt.SWT;
import org.eclipse.swt.events.*;
import org.eclipse.swt.graphics.*;
import org.eclipse.swt.layout.*;
import org.eclipse.swt.widgets.*;
 * This class demonstrates a Canvas
public class SimpleCanvas {
   * Runs the application
  public void run() {
    Display display = new Display();
    Shell shell = new Shell(display);
    shell.setText("Canvas Example");
    createContents(shell);
    shell.open();
    while (!shell.isDisposed()) {
      if (!display.readAndDispatch()) {
        display.sleep();
    display.dispose();
   * Creates the main window's contents
   * @param shell the main window
  private void createContents(Shell shell) {
    shell.setLayout(new GridLayout());
    // Create a button on the canvas
    Combo combo = new Combo(shell, SWT.PUSH);
    //combo.setBounds(10, 10, 300, 40);
    combo.setItems(new String[]{"ONE","TWO","FOUR","FIVE"});
    combo.setLayoutData(new GridData(GridData.FILL_HORIZONTAL));
 // Create a canvas
    Canvas canvas = new Canvas(shell, SWT.BORDER);
    canvas.setLayoutData(new GridData(GridData.FILL_BOTH));
    // Create a paint handler for the canvas
        // Do some drawing
        Rectangle rect = ((Canvas) e.widget).getClientArea();
        e.gc.setBackground(e.display.getSystemColor(SWT.COLOR_RED));
        e.gc.fillRectangle(rect);
   * The application entry point
   * @param args the command line arguments
    new SimpleCanvas().run();
Re: How to repair canvas? [message #534394 is a reply to message #534321] Tue, 18 May 2010 21:15 Go to previous message
Issue solved: I was using gc.getClipping() rather than canvas.getClientArea() when calculating how to place lines etc. When drawing the canvas first (or switching windows) the clipping equals the client area; but this is not the case when repairing the damage done after being partially overlapped.
Previous Topic:Scrollbar not appearing at startup
Next Topic:SWT.Show not called for child widgets?
Current Time: Fri Jul 25 21:27:51 EDT 2025
Powered by FUDForum. Page generated in 0.04904 seconds
