Changing parent of widgets problem [message #534178] |
Tue, 18 May 2010 05:47  |
Hello peoples,
I am trying to change (at runtime) the parent of a widget.
Use case (not saying yet whether runtime switching is the correct approach):
Build up a set of widgets, and then move them arôund according to the
desired view.
Wondering why the below code doesn't work? Specifically, when I hit the
"change parent" button, the labels just disappear (even though isVisible()
returns true).
public void createPartControl(Composite parent) {
Composite master = new Composite(parent, SWT.NONE);
master.setLayout(new GridLayout(2, false));
shell1 = new Composite(master, SWT.NONE);
shell1.setLayout(new FillLayout(SWT.VERTICAL));
shell2 = new Composite(master, SWT.NONE);
shell2.setLayout(new FillLayout(SWT.VERTICAL));
Button change = new Button(shell1, SWT.NONE);
change.setText("change parent");
change.addSelectionListener(this);
lbl = new Label(shell1, SWT.NONE);
lbl.setText("start in shell1:reparentable?" + lbl.isReparentable());
lbl2 = new Label(shell2, SWT.NONE);
lbl2.setText("start in shell2");
public void widgetSelected(SelectionEvent e) {
if (lbl.getParent() == shell1)
lbl.setParent(shell2);
else
lbl.setParent(shell1);
if (lbl2.getParent() == shell1)
lbl2.setParent(shell2);
else
lbl2.setParent(shell1);
lbl.setVisible(true);
lbl2.setVisible(true);
Re: Changing parent of widgets problem [message #534202 is a reply to message #534178] |
Tue, 18 May 2010 06:46   |
I think you should issue a layout() on the shells after having reparented
Tom
Am 18.05.10 11:47, schrieb geejay:
> Hello peoples,
> approach): Build up a set of widgets, and then move them arôund
> according to the desired view.
> isVisible() returns true).
> @Override
> else
> else
Re: Changing parent of widgets problem [message #534219 is a reply to message #534202] |
Tue, 18 May 2010 07:51  |
Thanks Tom, yes, that worked simply calling shell.layout(). Thanks again!
"Tom Schindl" <tom.schindl@bestsolution.at> wrote in message
news:hstr6k$559$1@build.eclipse.org...
> Tom
>> Hello peoples,
>> @Override
>> else
>> else
FUDForum. Page generated in 0.06343 seconds
