Home » Modeling » OCL » OCL constraint: blank character in a string(OCL constraint that checks the blank character in a string)
OCL constraint: blank character in a string [message #533329] Thu, 13 May 2010 08:14 Go to next message
Hi there,
I have a trouble in an OCL constraint that checks the blank characters in a string. I cannot write a constraint using the operations defined on OCL String. Following constraint is not working either. Could anyone help me?
 " not (self.name->includes(' ')) "
[Updated on: Thu, 13 May 2010 08:15] by Moderator
Re: OCL constraint [message #533765 is a reply to message #533329] Sun, 16 May 2010 16:43 Go to previous messageGo to next message
Originally posted by: Alexander.Igdalov.gmail.com
Hi Esin,
I would recommend you to write this operation in Java. Refer to
"Customizing the Environment" section of the OCL Developer Guide (in
Help) for details.
Your statement
doesn't check for spaces but converts a String (i.e. self.name) to a Set
of Strings containing one element (self.name) and attempts to find a
String equal to ' '.
HTH,
- Alex.
esin wrote:
> Hi there,
> help me?
Re: OCL constraint [message #533773 is a reply to message #533329] Sun, 16 May 2010 17:20 Go to previous messageGo to next message
Hi esin
OCL 2.2 adds
String::characters() : Sequence(String)
which breaks a String up into one chaacer per String allowing you to do
what you want.
Unfortunately MDT/OCL does not yet support this function. Should be in
MDT/OCL 4.0.0.
For now, as Alex suggested, you need Java, which will also be much
easier in MDT/OCL 4.0.0.
Ed Willink
On 13/05/2010 13:14, esin wrote:
> Hi there,
> help me?
Re: OCL constraint [message #533921 is a reply to message #533329] Mon, 17 May 2010 09:28 Go to previous messageGo to next message
Hi, all,
A less pleasant-looking alternative to Java is:
(1..self.name.size())->collect(i |
self.name.substring(i, i))->excludes(' ')
which basically includes an expansion of the OCL 2.2 characters() operation.
Christian
On 13/05/10 08:14 AM, esin wrote:
> Hi there,
> help me?
Re: OCL constraint [message #533935 is a reply to message #533921] Mon, 17 May 2010 10:06 Go to previous messageGo to next message
Cool! That's what an expert advice is!
Christian W. Damus wrote:
> Hi, all,
> operation.
> Christian
>> Hi there,
>> help me?
Re: OCL constraint [message #533946 is a reply to message #533921] Mon, 17 May 2010 10:27 Go to previous message
Hi all,
Thanks for your replies. With the helps of all you, i solved my problem. And here is the solution:
Sequence{1..self.name.size()}->collect(i |self.name.substring(i, i))->excludes(' ')
Previous Topic:Re: EAnnotations and their contents
Next Topic:Add Pacakge imports to the OclParser
Current Time: Sat Jul 26 01:56:37 EDT 2025
Powered by FUDForum. Page generated in 0.29421 seconds
