Home » Modeling » GMF (Graphical Modeling Framework) » Duplicate UUID's corrupting the diagrams
Duplicate UUID's corrupting the diagrams [message #533646] Fri, 14 May 2010 17:52 Go to next message
Not sure if this or EMF is the correct newsgroup so I will start here...
When we create our diagrams (programatically create elements on the
diagram), or copy and paste and a large # of elements on our diagram,
our diagrams will eventually get a duplicate UUID(s) and become corrupt
(randomly).
It appears that the generateUUID method is returning the same value one
multiple calls?
In my *Resource class in attachedHelper, is there anything I can do to
verify the id has not already been used and generate a new one if it
has? Seems like there could be alot of overhead checking all previous
uuids when generating new ones... Ive gone as far as trying to append
the nanotime to the uuid, but then my diagrams wont open i assume from
the uuid not being valid, as when I revery it is fine...
I believe the only reason we use UUID's is for Copy and Paste, is that
still necessary?
any pointers would be helpful
Re: Duplicate UUID's corrupting the diagrams [message #533693 is a reply to message #533646] Sat, 15 May 2010 12:47 Go to previous messageGo to next message
--------------030602080602000000030303
Brian,
Comments below.
> corrupt (randomly).
I'm not sure how that's possible given the ID is set like this in
XMLResourceImpl:
public void setID(EObject eObject, String id)
Object oldID = id != null ? getEObjectToIDMap().put(eObject, id)
: getEObjectToIDMap().remove(eObject);
if (oldID != null)
getIDToEObjectMap().remove(oldID);
if (id != null)
getIDToEObjectMap().put(id, eObject);
> one multiple calls?
I think that's impossible. The system clock is encoded as part of the
value.
The UUID generator will actually sleep to avoid generating too many
UUIDs within a given clock tick.
> still necessary?
> Thanks
Content-Type: text/html; charset=ISO-8859-1
<html>
<head>
</head>
Brian,<br>
<br>
Comments below.<br>
<br>
<blockquote cite="mid:hskgmi$13v$1@build.eclipse.org" type="cite">Not
<br>
<br>
(randomly).
<br>
</blockquote>
XMLResourceImpl:<br>
<blockquote><small>&nbsp; public void setID(EObject eObject, String id)</small><br>
<small>&nbsp; {</small><br>
<small>&nbsp;&nbsp;&nbsp; Object oldID = id != null ?
getEObjectToIDMap().put(eObject, id) :
getEObjectToIDMap().remove(eObject);</small><br>
<small>&nbsp;&nbsp;&nbsp; </small><br>
<small>&nbsp;&nbsp;&nbsp; if (oldID != null)</small><br>
<small>&nbsp;&nbsp;&nbsp; {</small><br>
<small>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; getIDToEObjectMap().remove(oldID);</small><br>
<small>&nbsp;&nbsp;&nbsp; }</small><br>
<small>&nbsp;&nbsp;&nbsp; if (id != null)</small><br>
<small>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; getIDToEObjectMap().put(id, eObject);</small><br>
<small>&nbsp; }</small><br>
</blockquote>
<br>
<blockquote cite="mid:hskgmi$13v$1@build.eclipse.org" type="cite">It
multiple calls?
<br>
</blockquote>
I think that's impossible.&nbsp; The system clock is encoded as part of the
value.<br>
<blockquote cite="mid:hskgmi$13v$1@build.eclipse.org" type="cite"><br>
has?&nbsp; Seems like there could be alot of overhead checking all previous
uuids when generating new ones...&nbsp; Ive gone as far as trying to append
<br>
</blockquote>
UUIDs within a given clock tick.<br>
still necessary?
<br>
<br>
<br>
<br>
</blockquote>
</body>
</html>
--------------030602080602000000030303--
Re: Duplicate UUID's corrupting the diagrams [message #533841 is a reply to message #533693] Mon, 17 May 2010 05:21 Go to previous message
Ed Merks a écrit :
> Brian,
> Comments below.
>> corrupt (randomly).
> XMLResourceImpl:
> if (oldID != null)
> if (id != null)
>> one multiple calls?
> value.
>> still necessary?
yep using UUID's is still necessary for Copy/Paste in GMF.
>> Thanks
Previous Topic:Epackage registration
Next Topic:Problem with Outline view
Current Time: Wed Jul 23 04:08:21 EDT 2025
Powered by FUDForum. Page generated in 0.26113 seconds
