Home » Modeling » M2T (model-to-text transformation) » [Acceleo] Java application runner
[Acceleo] Java application runner [message #503175] |
Fri, 11 December 2009 04:48  |
my M2T transformation launching works when using "Acceleo plug-in application" runner in Eclipse launch configuration. But when using Java application runner I get PackageNotFoundException from Ecore XMLHandler:
Caused by: org.eclipse.emf.ecore.xmi.PackageNotFoundException: Package with uri 'http://myproject/ns/mymetamodel' not found. (file:/R:/eclipse_workspace/MyProject/resources/models/MyModel.xmi, 3, 88)
Models are stored in separate project from Acceleo module project and I refer to metamodels by URI in Acceleo templates. Opening MyModel.xmi in sample Ecore editor works fine. What might cause the error here? My eventual goal behind this is to run transformations with Ant.
Ilari
Re: [Acceleo] Java application runner [message #503188 is a reply to message #503175] |
Fri, 11 December 2009 00:32   |
--------------000205030909070807070306
Hi Ilari,
Running "Acceleo plu-in application" is running your generation within
an eclipse context, running as a "Java application" means running your
generation standalone.
Standalone runs require some more setup from your side; the main issue
being registering your metamodels in the package registry. Look at the
way it is done for UML :
http://wiki.eclipse.org/MDT/UML2/FAQ#What.27s_required_to_lo ad_a_UML_.28.uml.29_resource_from_a_standalone_application.3 F
What's important for you in there are the lines
resourceSet.getPackageRegistry().put(UMLPackage.eNS_URI,
UMLPackage.eINSTANCE);
resourceSet.getResourceFactoryRegistry().getExtensionToFacto ryMap().put(UMLResource.FILE_EXTENSION,
UMLResource.Factory.INSTANCE);
Which goal is to register the package in the registry and associate a
given resource factory with the UML extension. You need to do the same,
replacing the UMLPackage by the XxxPackage that's been generated for
your metamodel, the "uml" file extension by yours, and the
UMLResource.Factory.INSTANCE by the one that's been generated for you
(if any, this might not be necessary)
Laurent Goubet
Obeo
Ilari Heikkinen wrote:
> (file:/R:/eclipse_workspace/MyProject/resources/models/MyMod el.xmi, 3, 88)
> Ilari
name="laurent_goubet.vcf"
filename="laurent_goubet.vcf"
bjoyLjENCmVuZDp2Y2FyZA0KDQo=
--------------000205030909070807070306--
Re: [Acceleo] Java application runner [message #503416 is a reply to message #503188] |
Sun, 13 December 2009 15:02   |
just added a line
resourceSet.getPackageRegistry().put(MyPackage.eINSTANCE.get NsURI(),
MyPackage.eINSTANCE);
to method registerPackages(ResourceSet resourceSet) in my template
module entry point class and it works.
-Ilari
On 11/12/09 12:27, Laurent Goubet wrote:
> Hi Ilari,
> Laurent Goubet
> Obeo
>> Hi,
>> XMLHandler:
>> 88)
>> Thanks,
>> Ilari
Re: [Acceleo] Java application runner [message #503451 is a reply to message #503416] |
Sun, 13 December 2009 23:38   |
--------------020002010508090501040302
Thanks for the feedback Ilari, glad that it works ^^.
> just added a line
> -Ilari
>> Hi Ilari,
>> Laurent Goubet
>> Obeo
>>> Hi,
>>> XMLHandler:
>>> 88)
>>> Thanks,
>>> Ilari
--------------020002010508090501040302--
Re: [Acceleo] Java application runner [message #533822 is a reply to message #533215] |
Mon, 17 May 2010 04:16  |
--------------030408060705060904000709
We have a known bug with the Acceleo "Java Application" launch. We're
trying to get this fixed for RC1 but it is unusable until then. Sorry
for the inconvenience.
Laurent Goubet
Obeo
koïta Aboubakar wrote:
> I'm also trying to launch acceleo generation in standalone, with Java
> launcher. I have not any exception, but also any generation in output.
> Only the output folder is created. And of course, my templates works
> with acceleo plugin
> Some explications ?
> Thanks
--------------030408060705060904000709--
Current Time: Wed Jul 23 18:18:51 EDT 2025
Powered by FUDForum. Page generated in 0.05448 seconds
