Home » Modeling » GMF (Graphical Modeling Framework) » Label Maping for a class
Label Maping for a class [message #530425] Thu, 29 April 2010 11:44 Go to next message
is it possible to define Label Mapping in GMF (for Link Mapping) for non-simple type (string), e.g., for some class?
thx, Milan
Re: Label Maping for a class [message #533331 is a reply to message #530425] Thu, 13 May 2010 08:26 Go to previous messageGo to next message
hi
I would like to push this old story as I have a similar 'problem'. Is it possible to use a referenced object (non-primitive, custom object) as label (or rather one of its attributes)?
e.g.,
Class NodeGtw references to one Node object which can be used by other NodeGtws as well. Node has one value and that's the name. I would like to show the name above the NodeGtw as the NodeGtw is a placeholder of a Node, adding some additional attributes/references.
I have experimented with GMF, but it did not work.
any hints? or is is just not possible?
thx for your help!
kr,
Patrick
Re: Label Maping for a class [message #533580 is a reply to message #533331] Fri, 14 May 2010 11:45 Go to previous messageGo to next message
I have exactly the same problem,
any help please?
Re: Label Maping for a class [message #535023 is a reply to message #530425] Fri, 21 May 2010 02:23 Go to previous messageGo to next message
sorry that I didn't get to answer earlier. I wrote an example about this feature and blogged about it last night: GMF: Labels With Values Of Referenced Model Elements. Hopefully this is helping you.
Rgrds
Robert
Re: Label Maping for a class [message #535325 is a reply to message #535023] Sat, 22 May 2010 06:26 Go to previous message
Thank you Robert!
I will try this out in the next few days. Thank you very much for your help and all the details specified.
br,
Patrick
Previous Topic:Diagram partitioning (double click) and intializing the sub-diagram
Next Topic:palette extension
Current Time: Mon Jul 21 06:01:13 EDT 2025
Powered by FUDForum. Page generated in 0.24443 seconds
