Home » Archived » BIRT » Set data set in java code
Set data set in java code [message #48269] Mon, 20 June 2005 14:02 Go to next message
I saw comments it's posibble but could find an example. The example in the
help just shows how to add element but not showing how to setup backend
data.
Thanks.
Jim
Re: Set data set in java code [message #48361 is a reply to message #48269] Mon, 20 June 2005 15:53 Go to previous messageGo to next message
> data.
> Thanks.
> Jim
hi jim
i have already announce this link in this newsgroup. btw you can find a
working example that use POJOs as datasources in my blog [1]
[1] http://tools.osmosis.gr/blog/archives/2005/06/birt_and_objec t.html
ps
don t forget to search this newsgroup for "POJO", "Script DataSet"
you will find some useful posts
regards
stavros
Re: Set data set in java code [message #48391 is a reply to message #48361] Mon, 20 June 2005 15:56 Go to previous messageGo to next message
I made this to work. I'm try to find a way to do in the java API directly.
How to do that?
Thanks.
Jim
"Stavros Kounis" <skounis@gmail.com> wrote in message
news:d976r8$83e$1@news.eclipse.org...
>> the help just shows how to add element but not showing how to setup
>> backend data.
>> Thanks.
>> Jim
> hi jim
> ps
> regards
> stavros
Re: Set data set in java code [message #48696 is a reply to message #48361] Tue, 21 June 2005 11:29 Go to previous messageGo to next message
This works on 3.0 but I got same error (?? is not a function) on 3.1. Anyone
knows how to fix it? Thanks.
>> backend data.
>> Thanks.
>> Jim
> hi jim
> ps
> regards
> stavros
Re: Set data set in java code [message #53358 is a reply to message #48696] Mon, 04 July 2005 16:13 Go to previous message
Birt Preview Web App (eclipse plugin) can
Previous Topic:Spring, Hibernate
Next Topic:BIRT & POJO objects
Current Time: Thu Sep 11 17:07:51 EDT 2025
Powered by FUDForum. Page generated in 0.06703 seconds
