Home » Eclipse Projects » Subversive » Subversive 0.7.9 Released
Subversive 0.7.9 Released [message #533318] Thu, 13 May 2010 05:48 Go to next message
Dear Subversive Users,
We are glad to announce that Subversive 0.7.9.I20100512-1900 release has
been published and available for download at
http://www.eclipse.org/subversive web site.
SVN Team Provider update site:
http://download.eclipse.org/technology/subversive/0.7/update -site/
SVN Connectors update site:
http://community.polarion.com/projects/subversive/download/e clipse/2.0/update-site/
A complete changelog is available at:
http://www.eclipse.org/subversive/changelogs/releasenotes.tx t
Best Regards,
Subversive Team
Re: Subversive 0.7.9 Released [message #533342 is a reply to message #533318] Thu, 13 May 2010 09:22 Go to previous messageGo to next message
Subversive requires JDK 1.5 or higher and supports following versions of Eclipse:
* 3.3 (tested with 3.3.2)
* 3.4 (tested with 3.4)
Eclipse 3.5 (galileo) is not supported ???
Re: Subversive 0.7.9 Released [message #533427 is a reply to message #533318] Thu, 13 May 2010 16:31 Go to previous messageGo to next message
Installation of this set of updates is failing in my Eclipse 3.5.2 installation with the following:
An error occurred during the org.eclipse.equinox.internal.provisional.p2.engine.phases.Ch eckTrust phase.
session context was:(profile=PlatformProfile, phase=org.eclipse.equinox.internal.provisional.p2.engine.pha ses.CheckTrust, operand=, action=).
One or more certificates rejected. Cannot proceed with installation.
When I step through the installation, I see one dialog that I don't believe I've ever seen while installing plugins, which is a "Selection Needed" dialog that asks me "Do you trust these certificates?". The cert is issued by "VeriSign\, Inc.", and it isn't expired. I clicked OK, and then immediately got this error dialog.
Re: Subversive 0.7.9 Released [message #533429 is a reply to message #533427] Thu, 13 May 2010 16:46 Go to previous messageGo to next message
Oh. Duh. I suppose checking the checkbox for the certificate saying that I trust it would be useful. Smile
You'd think the process would be a little more intelligent, like telling me that I can't install the plugin if I don't check the checkbox.
Re: Subversive 0.7.9 Released [message #533440 is a reply to message #533429] Thu, 13 May 2010 18:05 Go to previous messageGo to next message
Thu, 13 May 2010 16:46:25 -0400, /David M. Karr/:
> I trust it would be useful. :)
I get this certificate dialog using the 3.5.2 JEE package and if I'm
not mistaken not only while installing Subversive but with other
official Galileo packages, also. I don't get this with a bare 3.5.2
Platform Runtime which have my necessary Galileo packages installed
on top.
Stanimir
Re: Subversive 0.7.9 Released [message #533471 is a reply to message #533342] Fri, 14 May 2010 03:25 Go to previous messageGo to next message
Hello David,
Of course, Eclipse 3.5 and 3.6 are supported, I'll update changelog. Thanks.
> Quote:
>> of Eclipse:
Igor Burilo
Re: Subversive 0.7.9 Released [message #533474 is a reply to message #533429] Fri, 14 May 2010 03:36 Go to previous messageGo to next message
Hello David,
Subversive doesn't require any certificates during installation, it's
some P2 issue.
Igor Burilo
Re: Subversive 0.7.9 Released [message #533484 is a reply to message #533318] Fri, 14 May 2010 04:44 Go to previous messageGo to next message
Hi!
Can all of you who posted here in this thread please tell how you replied?
- on the web : http://www.eclipse.org/forums/...
- over email
- NNTP
- other ?
This is to hunt down the cause of a bug, see:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=291441#c15
Thanks.
Re: Subversive 0.7.9 Released [message #533557 is a reply to message #533318] Fri, 14 May 2010 10:34 Go to previous messageGo to next message
I updated and now every time I start Eclipse (JEE 3.5.2) I get the SVN Connectop eselection dialog, where I select SVNKit 1.3.0.
Then installation fails with the message:
Cannot complete the request. See the error log for details.
"SVNKit 1.3.0 Implementation (Optional)" will be ignored because a newer version is already installed.
"Subversive SVN Connectors" will be ignored because a newer version is already installed.
I can only cancel the wizard.
If I try to use SVN functionality, I get an error:
org.eclipse.team.svn.core.operation.UnreportableException: Selected SVN connector library is not available or cannot be loaded.
If you selected native JavaHL connector, please check if binaries are available or install and select pure Java Subversion connector from the plug-in connectors update site.
If connectors already installed then you can change the selected one at: Window->Preferences->Team->SVN->SVN Connector.
at org.eclipse.team.svn.core.extension.factory.ISVNConnectorFac tory$1.newInstance(ISVNConnectorFactory.java:105)
at org.eclipse.team.svn.core.svnstorage.SVNRepositoryLocation.n ewProxyInstance(SVNRepositoryLocation.java:750)
at org.eclipse.team.svn.core.svnstorage.SVNRepositoryLocation.a cquireSVNProxy(SVNRepositoryLocation.java:542)
at org.eclipse.team.svn.core.svnstorage.SVNRepositoryContainer. getChildren(SVNRepositoryContainer.java:77)
I checked and I have SVNKit 1.3.2 installed and also
Subversive SVN Connectors 2.2.2.I20100512-1900 org.polarion.eclipse.team.svn.connector.feature.group
I will now uninstall them and try again.
[Updated on: Fri, 14 May 2010 10:37] by Moderator
Re: Subversive 0.7.9 Released [message #533559 is a reply to message #533474] Fri, 14 May 2010 10:40 Go to previous messageGo to next message
Igor Burilo wrote on Fri, 14 May 2010 09:36
Hello David,
some P2 issue.
I get a warning dialog about installing unsigned content.
With a click OK it continues.
Not sure if this is the same David reported.
Re: Subversive 0.7.9 Released [message #533560 is a reply to message #533557] Fri, 14 May 2010 10:44 Go to previous messageGo to next message
David Balažic wrote on Fri, 14 May 2010 16:34
That worked. I uninstalled those two, restarted Eclpse and again it showed the SVN connector dialog, I selected SVNKit 1.3.0* and it installed and works fine.
But!
If I click menu Help / Check for Updates, it finds and offers SVNKit 1.3.2 and Subversive SVN Connectors 2.2.2.I20100512-1900.
Is it safe to update?
This is all a bit confusing, I must admit.
* - (fixed typo: I installed SVNKit 1.3.0 , not 1.3.2. I fixed the text above)
[Updated on: Mon, 17 May 2010 04:26] by Moderator
Re: Subversive 0.7.9 Released [message #533812 is a reply to message #533557] Mon, 17 May 2010 03:42 Go to previous messageGo to next message
Hello David,
Could you please provide what Subversive, SVN Connectors version you
already have in Eclipse?
Please, try to completely unistall SVN Connectors.
> replied?
NNTP
> version is already installed. "Subversive SVN Connectors" will be
Igor Burilo
Re: Subversive 0.7.9 Released [message #533813 is a reply to message #533560] Mon, 17 May 2010 03:47 Go to previous messageGo to next message
Hello David,
SVN Connectors 2.2.2.I20100512-1900 is latest connectors version from
release. But it's strange that you are proposed to install SVN
Connectors 2.2.2.I20100512-1900 in Menu/Check For Updates if you already
have this version.
> showed the SVN connector dialog, I selected SVNKit 1.3.2 and it
> But!
Igor Burilo
Re: Subversive 0.7.9 Released [message #533821 is a reply to message #533318] Mon, 17 May 2010 04:23 Go to previous messageGo to next message
I guess you misread.
- first I had SVNKit 1.3.2
It did not work
- then I uninstalled it (SVNKit 1.3.2)
- then I installed SVNKit 1.3.0
That works.
But now when I do Find updates, it finds and offers SVNKit 1.3.2.
But as I had it before and did not work, I don't know if I should accept the offered update or not.
Re: Subversive 0.7.9 Released [message #533823 is a reply to message #533318] Mon, 17 May 2010 04:28 Go to previous messageGo to next message
Just to note, in the older message, I said that I installed SVNKit 1.3.2.
That was a typo. I actually selected and installed v1.3.0. (I edited the message on the forum now)
Sorry about that.
(my last message before this one has the versions correctly)
[Updated on: Mon, 17 May 2010 04:28] by Moderator
Re: Subversive 0.7.9 Released [message #534281 is a reply to message #533318] Tue, 18 May 2010 10:49 Go to previous messageGo to next message
Galileo Update site doesn't provide an updated version of Subversive. So under normal circumstances only the connectors get updated.
Awkwardly, the most recent version of Subversive isn't willing to work together with these too new connectors.
What you need to do is to also update Subversive by manually entering the Update-Site URL from the first post
and install the Subversive version from there (this will perform an update).
Hope this helps.
Andreas
Re: Subversive 0.7.9 Released [message #535049 is a reply to message #533823] Fri, 21 May 2010 03:50 Go to previous messageGo to next message
Hello David,
When you have Subversive 0.7.9 installed then Connector Discovery dialog
has to propose to install SVN Kit 1.3.2 but not 1.3.0.
So, please check that you do have Subversive 0.7.9, and if not please,
update Subversive to 0.7.9 at first.
> That was a typo. I actually elected and installed v1.3.0. (I edited the
> Sorry about that.
Igor Burilo
Re: Subversive 0.7.9 Released [message #535052 is a reply to message #534281] Fri, 21 May 2010 03:54 Go to previous messageGo to next message
Hello Andreas,
We can't propogate latest Subversive release to galileo update site as
there're no more releases for Galileo. But latest Subversive release
will appear in Helios update site, until that you can get latest
Subversive from
http://download.eclipse.org/technology/subversive/0.7/update -site/ as
you wrote.
> update).
> Hope this helps.
> Regards
> Andreas
Igor Burilo
Re: Subversive 0.7.9 Released [message #535064 is a reply to message #535049] Fri, 21 May 2010 04:24 Go to previous messageGo to next message
Igor Burilo wrote on Fri, 21 May 2010 09:50
Hello David,
I have 0.7.8.
Strange,I was 100% I installed the latest version.
Sorry for confusing information.
PS: Can you answer my question about the way you post here?
(in regards to https://bugs.eclipse.org/bugs/show_bug.cgi?id=291441#c15 )
Re: Subversive 0.7.9 Released [message #535680 is a reply to message #535064] Tue, 25 May 2010 05:00 Go to previous messageGo to next message
Hello David,
I already answered, anyway I'm using Mozilla Thunderbird, NNTP. Or
should I answer directly in bug?
>> Hello David,
>> dialog has to propose to install SVN Kit 1.3.2 but not 1.3.0.
> I have 0.7.8.
Igor Burilo
Re: Subversive 0.7.9 Released [message #535730 is a reply to message #535680] Tue, 25 May 2010 08:42 Go to previous messageGo to next message
Oh, sorry, I did not notice.
Re: Subversive 0.7.9 Released [message #537435 is a reply to message #533318] Wed, 02 June 2010 08:50 Go to previous messageGo to next message
works very well (i can "tag" again).
my question is, why isn't it published into the default galileo-update site?
Re: Subversive 0.7.9 Released [message #537461 is a reply to message #537435] Wed, 02 June 2010 09:53 Go to previous message
Wed, 02 Jun 2010 08:50:59 -0400, /Alexander Malic/:
> site?
Already answered in this same thread:
http://www.eclipse.org/forums/index.php?t=msg&&th=16 8116&goto=534281#msg_535052
Stanimir
Previous Topic:Weird state that ends up creating commits that remove files from repository
Next Topic:merging subversion
Current Time: Wed Jul 23 23:59:29 EDT 2025
Powered by FUDForum. Page generated in 0.28871 seconds
