Home » Eclipse Projects » Rich Client Platform (RCP) » Inputs To Commands
Inputs To Commands [message #533424] Thu, 13 May 2010 15:58 Go to next message
I have an application that displays information in a tree. I would like to add a command that allows me to override the delete key to delete a node from the tree. The command works in the sense that it now overrides the delete key and calls the execute method in the handler for the command. Right now it just throws a message saying that my handler has been called.
My question is how can I get the handler class to know about the ViewPart class that holds the tree to do the delete? I was thinking that I could have the handler class fire an event into the wiew, but I have no idea how to get the handler to know about the view. Is there a way for the ViewPart when it is creating itself to get a hold of the command and pass "this" to the handler so that the handler can add the view as a listener and then fire an event into the view? Is there any standard way of having a view and a handler for a command to communicate with each other?
Andy
Re: Inputs To Commands [message #533527 is a reply to message #533424] Fri, 14 May 2010 08:51 Go to previous messageGo to next message
Check out ISources and HandlerUtil. HandlerUtil can extract the active
part from the ExecutionEvent, which will be your ViewPart.
You can also activate your handler from your view's createPartControl,
at which point you can tell it about your viewer.
PW
Paul Webster
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/guide/workbench.htm
Re: Inputs To Commands [message #533545 is a reply to message #533424] Fri, 14 May 2010 10:07 Go to previous message
Thanks!
IWorkbenchPart viewer = HandlerUtil.getActivePart(event);
did the trick.
Previous Topic:Problems with custom config.ini
Next Topic:How to access Velocity templates in a plugin
Current Time: Sat Jul 26 08:36:06 EDT 2025
Powered by FUDForum. Page generated in 0.07901 seconds
