Home » Modeling » M2T (model-to-text transformation) » Extend file(Perform getEStructuralFeature)
Extend file [message #533347] Thu, 13 May 2010 09:36 Go to next message
I write this function on a extend file but its uncomplete:
String typeSet(String s):
JAVA getEStructuralFeature(java.lang.String)
i want to check if an element "type" in my metamodel got a name,
so i need to have access to the element and to test if the name isnt null, by using just an en Extend files
mahmoud
Re: Extend file [message #533373 is a reply to message #533347] Thu, 13 May 2010 11:04 Go to previous messageGo to next message
what is your actual question? what is your metamodel like? can you explain more details?
If You want to use a java extension you have to specify the fully qualified classname before the method name.
If you use ECore as MetaModel you could test the ecore:EClass for the name feature as follows: this.eStructuralFeatures.select(e|e.name == "name").size == 1
~Christian
[Updated on: Thu, 13 May 2010 11:34] by Moderator
Re: Extend file [message #533491 is a reply to message #533373] Fri, 14 May 2010 05:00 Go to previous messageGo to next message
Hi Christian,
I have a metamodel like a class diagram, and i want to check if an attribute got a type, i used before :
t
context class::attribute error '' need a type" :
]his.type.name !=null
and i want to perform the same validation using an eStructuralFeatures
mahmoud
Re: Extend file [message #533497 is a reply to message #533491] Fri, 14 May 2010 05:43 Go to previous messageGo to next message
hello,
still don't understand why this is a problem
context EStructuralFeature ERROR "EStructural features must have a type with a name" :
	this.eType.name != null;
EMF Docs might help http://download.eclipse.org/modeling/emf/emf/javadoc/2.5.0/o rg/eclipse/emf/ecore/package-summary.html#details
Regards Christian
[Updated on: Fri, 14 May 2010 05:44] by Moderator
Re: Extend file [message #533594 is a reply to message #533497] Fri, 14 May 2010 12:33 Go to previous message
H Christian,
soory its my fault, i have my own metamodel, with its elements (but it still an ecore),i have some element that i used to access directlly but now, i want to used some ecore functions.
i nedd to do this :
context Entities::Attribute ERROR "msg" :
this.eClass().getEstructuralFeature("type").name!=null;
Entities : its my Epackage.
mahmoud
Previous Topic:<Xtend> How to delete a UseCase from a list
Next Topic:[XPAND/XTEND] defining aliases
Current Time: Wed Jul 23 04:07:46 EDT 2025
Powered by FUDForum. Page generated in 0.04860 seconds
