Home » Eclipse Projects » Standard Widget Toolkit (SWT) » UI layout suggestions
UI layout suggestions [message #533165] Wed, 12 May 2010 09:31 Go to next message
I have a requirement where I need to lead a user through a number of data
entry sections.
I have an RCP app, with a main editor, which is implemented as an Eclipse
form.
Once data is validated, I want a new section to appear under the existing
section.
I was thinking about using expandable Sections, but was wondering if there
was some other style I could use?
Re: UI layout suggestions [message #533340 is a reply to message #533165] Thu, 13 May 2010 08:46 Go to previous message
I think you are on the right path. There has been many eclipse dialogs
using similar functionality. You might use Spy plugin (Alt+Shift+F1) to
see the implementation of those dialogs and verify the behavior.
Anyway, the right place where this question can be best answered is
eclipse.platform or eclipse.platform.jface. So, please cross post this
question at those forums.
Previous Topic:StyledCellLabelProvider ignores fontStyle
Next Topic:Remove PaintListener in SWT
Current Time: Sun Aug 31 12:58:56 EDT 2025
Powered by FUDForum. Page generated in 0.11346 seconds
