Failure to export GMF/RCP using a Prdouct Configuration file. [message #533261] |
Wed, 12 May 2010 14:46  |
Originally posted by: rbbnjmn.yahoo.com
I have a Product Configuration I want to use to export my GMF projects.
I specified RCP in the code generation, and all this works perfectly
when launching the diagram application. I can also launch the
application from the Product Configuration, again all OK.
In the dependencies tab I have the three EMF/GMF projects, then click
Add required Plug-ins.
Now to export the plugin based application I want.
I have a problem I cannot work around. During the export one or more
dependencies cannot be resolved. On investigation I always find that
the 'missing' plugin is perfectly valid and sitting right there in the
Galileo plugin directory.
The most common culprit is: org.w3c.dom.smil, needed by one or more
batik plugins...
It's impossible for now to export an application....
Any help appreciated
Re: Failure to export GMF/RCP using a Prdouct Configuration file. [message #533316 is a reply to message #533261] |
Thu, 13 May 2010 05:09  |
> dependencies cannot be resolved. On investigation I always find that the
> batik plugins...
Hi there
I had similar problems (not for GMF) when exporting products, and I
noted that it was due to the fact that it was trying to export an old
version of a plugin which was still there in the plugins directory, and
not the most up-to-date version... removing manually the jar file and
restarting eclipse solved the problem for me...
hope this helps
Lorenzo
ICQ# lbetto, 16080134 (GNU/Linux User # 158233)
HOME: http://www.lorenzobettini.it MUSIC: http://www.purplesucker.com
http://www.myspace.com/supertrouperabba
BLOGS: http://tronprog.blogspot.com http://longlivemusic.blogspot.com
http://www.gnu.org/software/src-highlite
http://www.gnu.org/software/gengetopt
http://www.gnu.org/software/gengen http://doublecpp.sourceforge.net
FUDForum. Page generated in 0.05606 seconds
