Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » EMF Compare problem comparing instances
EMF Compare problem comparing instances [message #531030] Mon, 03 May 2010 08:56 Go to next message
I've got a problem when comparing instances with EMF Compare.
We created some dynamic instances of our meta model with the 'Create dynamic instances...' dialog of the sample ecore editor.
If I compare instances with EMF Compare, I'll always get error messages like 'The feature 'name' is not a valid feature' when expanding the tree in the top part of the compare editor.
Does EMF Compare work with dynamic instances or do I have to generate the code from the meta model? If I generate the code it works fine, but I would rather prefer to work with dynamic instances.
Could it be, that the meta model wasn't loaded correctly?
Here is the stack trace:
java.lang.IllegalArgumentException: The feature 'name' is not a valid feature
at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eOpenGet(BasicEO bjectImpl.java:1064)
at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eGet(BasicEObjec tImpl.java:1017)
at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eGet(BasicEObjec tImpl.java:1005)
at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eGet(BasicEObjec tImpl.java:1000)
at org.eclipse.emf.compare.diff.provider.UpdateAttributeItemPro vider.getText(UpdateAttributeItemProvider.java:98)
at org.eclipse.emf.edit.ui.provider.AdapterFactoryLabelProvider .getText(AdapterFactoryLabelProvider.java:380)
at org.eclipse.emf.compare.ui.viewer.structure.ModelStructureMe rgeViewer$ModelStructureLabelProvider.getText(ModelStructure MergeViewer.java:394)
at org.eclipse.jface.viewers.WrappedViewerLabelProvider.getText (WrappedViewerLabelProvider.java:108)
at org.eclipse.jface.viewers.WrappedViewerLabelProvider.update( WrappedViewerLabelProvider.java:164)
at org.eclipse.jface.viewers.ViewerColumn.refresh(ViewerColumn. java:145)
at org.eclipse.jface.viewers.AbstractTreeViewer.doUpdateItem(Ab stractTreeViewer.java:932)
at org.eclipse.jface.viewers.AbstractTreeViewer$UpdateItemSafeR unnable.run(AbstractTreeViewer.java:102)
at org.eclipse.core.runtime.Platform.run(Platform.java:888)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:48)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:17 5)
at org.eclipse.jface.viewers.AbstractTreeViewer.doUpdateItem(Ab stractTreeViewer.java:1012)
at org.eclipse.jface.viewers.StructuredViewer$UpdateItemSafeRun nable.run(StructuredViewer.java:481)
at org.eclipse.jface.viewers.StructuredViewer.updateItem(Struct uredViewer.java:2111)
at org.eclipse.jface.viewers.AbstractTreeViewer.createTreeItem( AbstractTreeViewer.java:827)
at org.eclipse.jface.viewers.AbstractTreeViewer$1.run(AbstractT reeViewer.java:802)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:70)
at org.eclipse.jface.viewers.AbstractTreeViewer.createChildren( AbstractTreeViewer.java:776)
at org.eclipse.jface.viewers.TreeViewer.createChildren(TreeView er.java:639)
at org.eclipse.jface.viewers.AbstractTreeViewer.handleTreeExpan d(AbstractTreeViewer.java:1442)
at org.eclipse.jface.viewers.TreeViewer.handleTreeExpand(TreeVi ewer.java:937)
at org.eclipse.jface.viewers.AbstractTreeViewer$4.treeExpanded( AbstractTreeViewer.java:1453)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:126)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1003)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1027)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1012)
at org.eclipse.swt.widgets.Tree.wmNotifyChild(Tree.java:7349)
at org.eclipse.swt.widgets.Control.wmNotify(Control.java:4877)
at org.eclipse.swt.widgets.Composite.wmNotify(Composite.java:17 57)
at org.eclipse.swt.widgets.Control.WM_NOTIFY(Control.java:4507)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:4000 )
at org.eclipse.swt.widgets.Display.windowProc(Display.java:4589 )
at org.eclipse.swt.internal.win32.OS.CallWindowProcW(Native Method)
at org.eclipse.swt.internal.win32.OS.CallWindowProc(OS.java:231 3)
at org.eclipse.swt.widgets.Tree.callWindowProc(Tree.java:1530)
at org.eclipse.swt.widgets.Tree.WM_LBUTTONDOWN(Tree.java:6280)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:3981 )
at org.eclipse.swt.widgets.Tree.windowProc(Tree.java:5821)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:4602 )
at org.eclipse.swt.internal.win32.OS.DispatchMessageW(Native Method)
at org.eclipse.swt.internal.win32.OS.DispatchMessage(OS.java:24 10)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3471)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2405)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2369)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 21)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:500)
at org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:332)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:493)
at org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:113)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:194)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:368)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:25)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 559)
at org.eclipse.equinox.launcher.Main.main(Main.java:1287)#
Thanks in advance
Johannes
Re: EMF Compare problem comparing instances [message #532856 is a reply to message #531030] Tue, 11 May 2010 07:36 Go to previous messageGo to next message
Does anybody have the same problem?
Is it even possible to compare instances created over the "create dynamic instance" dialog?
Do you need more information?
Johannes Albrecht
Re: EMF Compare problem comparing instances [message #533073 is a reply to message #532856] Wed, 12 May 2010 03:49 Go to previous messageGo to next message
--------------020501050807050202000906
Hi Johannes,
Sorry, seems like I let your previous mail slip through (please use the
EMF newsgroup for EMF Compare questions).
I must confess we never tried comparing dynamic instances, and it isn't
part of our tests. Could you try with the latest version of EMF Compare
and raise a bug if it is still failing with a "feature not found" error?
Laurnt Goubet
Obeo
> Johannes Albrecht
name="laurent_goubet.vcf"
filename="laurent_goubet.vcf"
bjoyLjENCmVuZDp2Y2FyZA0KDQo=
--------------020501050807050202000906--
Re: EMF Compare problem comparing instances [message #533121 is a reply to message #533073] Wed, 12 May 2010 06:27 Go to previous messageGo to next message
My guess from the description is that there are two instances of some
Ecore model and then a dynamic instance of one is being compared against
a dynamic instance of the other. Such things should not end up
comparing as structurally equal because their Ecore models are not
identical. But this is of course just a guess based on the symptoms.
Laurent Goubet wrote:
> Hi Johannes,
> the EMF newsgroup for EMF Compare questions).
> isn't part of our tests. Could you try with the latest version of EMF
> Compare and raise a bug if it is still failing with a "feature not
> found" error?
> Laurnt Goubet
> Obeo
>> Johannes Albrecht
Re: EMF Compare problem comparing instances [message #533140 is a reply to message #533121] Wed, 12 May 2010 07:44 Go to previous messageGo to next message
--------------080301040803050308020009
We indeed have a know bug when comparing two instances of distinct
metamodels ... I didn't understand the problem to be it in this case though.
>> Hi Johannes,
>> found" error?
>> Laurnt Goubet
>> Obeo
>>> Johannes Albrecht
--------------080301040803050308020009--
Re: EMF Compare problem comparing instances [message #622879 is a reply to message #531030] Tue, 11 May 2010 07:36 Go to previous messageGo to next message
Johannes Albrecht
Re: EMF Compare problem comparing instances [message #622884 is a reply to message #532856] Wed, 12 May 2010 03:49 Go to previous messageGo to next message
Hi Johannes,
Laurnt Goubet
Obeo
> Johannes Albrecht
Re: EMF Compare problem comparing instances [message #622885 is a reply to message #533073] Wed, 12 May 2010 06:27 Go to previous messageGo to next message
> Hi Johannes,
> found" error?
> Laurnt Goubet
> Obeo
>> Johannes Albrecht
Re: EMF Compare problem comparing instances [message #622886 is a reply to message #533121] Wed, 12 May 2010 07:44 Go to previous messageGo to next message
>> Hi Johannes,
>> found" error?
>> Laurnt Goubet
>> Obeo
>>> Johannes Albrecht
Re: EMF Compare problem comparing instances [message #673207 is a reply to message #622879] Sun, 22 May 2011 17:00 Go to previous message
Greetings,
I was having a similar problem. I seem to have found a solution.
Check: http://www.eclipse.org/forums/index.php/m/673206/#msg_673206
Later,
Frank
Previous Topic:[EEF] Custom Toolkit Widgets
Next Topic:EMF Compare problem comparing instances
Current Time: Sat Jul 26 20:20:32 EDT 2025
Powered by FUDForum. Page generated in 0.05181 seconds
