Home » Eclipse Projects » EGit / JGit » Installation (dependency) problem under Eclipse 3.6
Installation (dependency) problem under Eclipse 3.6 [message #532337] Sat, 08 May 2010 09:50 Go to next message
Hy.
I tried to install Egit from the recommended update site under Eclipse 3.6 (latest Milestone). But some dependencies couldn't be resolved:
An error occurred while collecting items to be installed
session context was:(profile=SDKProfile, phase=org.eclipse.equinox.internal.p2.engine.phases.Collect, operand=, action=).
No repository found containing: osgi.bundle,org.slf4j.api,1.5.11.v20100419-1106
Any suggestions what repo to add?
Kai
Re: Installation (dependency) problem under Eclipse 3.6 [message #532984 is a reply to message #532337] Tue, 11 May 2010 14:32 Go to previous messageGo to next message
I was able to do a clean install of Eclipse 3.6M7 Helios RCP bundle under Linux 32 bit. This includes Jgit and Egit in the bundle. I was also able to do a clean install of the Eclipse SDK 3.6M7 and use the pre-supplied Helios update site to install Jgit and Egit 0.7.1 without problems under Linux 32 bit.
Under Windows, the Helios 3.6M7 bundles are not currently available, but you can install either the 3.6M6 or 3.6M7 32 bit Eclipse SDK without problems, You can then use the pre-supplied Helios update site to install Jgit and Egit 0.7.1. I tested all these scenarios this morning and found them to all work.
My guess is that you may have tried to update a combination of packages at the same time and may have run into a packaging issue.
Re: Installation (dependency) problem under Eclipse 3.6 [message #533714 is a reply to message #532337] Sat, 15 May 2010 19:52 Go to previous message
This problem is fixed by http://egit.eclipse.org/r/#change,674.
This change has been merged into master on May 10.
Previous Topic:EGit push to GitHub freezes
Next Topic:Installation (dependency) problem under Eclipse 3.6
Current Time: Sat Jul 26 20:32:31 EDT 2025
Powered by FUDForum. Page generated in 0.04228 seconds
