[EMF Compare] UpdateReference: leftTarget or rightTarget? [message #532113] |
Fri, 07 May 2010 04:04  |
Hi again,
I was running my tests on the latest 3.6M7 release and I found out that
the leftTarget and rightTarget switched for updated references. Is that
intended or is it a mistake?
ReferenceCheck.createUpdatedReferenceOperation(..) in 3.5.1:
EObject rightTarget = getMatchedEObject(addedValue); // left: add
EObject leftTarget = getMatchedEObject(deletedValue); // right: del
// checks if target are defined remotely
if (leftTarget == null) {
leftTarget = deletedValue; // left: del
if (rightTarget == null) {
rightTarget = addedValue; // right: add
ReferenceCheck.createUpdatedReferenceOperation(..) in 3.6M7:
EObject leftTarget = getMatchedEObject(addedValue); // left: add ???
EObject rightTarget = getMatchedEObject(deletedValue); // right: del ???
Re: [EMF Compare] UpdateReference: leftTarget or rightTarget? [message #533022 is a reply to message #532818] |
Tue, 11 May 2010 18:09  |
Hi Laurent,
my transformation was retrieving the old and the new target from
UpdateReference.leftTarget and .rightTarget, this caused some confusion.
I fixed that by getting the actual targets directly from the model:
UpdateReference.leftElement.eGet(..) and
UpdateReference.rightElement.eGet(..) ;-)
Now it's working again.
Cheers
Patrick
Am 11.05.2010 11:36, schrieb Laurent Goubet:
> Hi Patrick,
> yup, this is a fix for bug
> https://bugs.eclipse.org/bugs/show_bug.cgi?id=292311 ; we previously
> reversed added and deleted elements. Is there still a bug with this
> configuration with your models?
> Laurent Goubet
> Obeo
> Patrick Könemann wrote:
>> Hi again,
>> that the leftTarget and rightTarget switched for updated references.
>> Is that intended or is it a mistake?
Re: [EMF Compare] UpdateReference: leftTarget or rightTarget? [message #622883 is a reply to message #532818] |
Hi Laurent,
Cheers
Patrick
> Hi Patrick,
> Laurent Goubet
> Obeo
>> Hi again,
FUDForum. Page generated in 0.48401 seconds
