Home » Archived » Buckminster » b3 aggregator problem
b3 aggregator problem [message #532539] Mon, 10 May 2010 08:30 Go to next message
I'm trying to create a p2 site using the aggregator, but I keep getting
the following error message:
> Build model validation failed: Diagnosis of
> org.eclipse.b3.aggregator.impl.AggregatorImpl@147b98c {file:/C:/work/dev/tooticki/core/ide/eclipse/features/com.ia r.hubble.releng/helios.b3aggr#/}
What does the error mean? The b3aggr file looks like this:
> <aggregator:Aggregator xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI" xmlns:aggregator="http://www.eclipse.org/b3/2010/aggregator/1.0.0">
> <contributions label="Helios">
> <repositories location="http://download.eclipse.org/releases/helios/"/>
> <repositories location="http://<path to intranet server>/cdt-master-7.0.0-I201003141308/"/>
> </contributions>
> </aggregator:Aggregator>
(replaced the name of our internal server holding the CDT update site).
/Jesper
Re: b3 aggregator problem [message #532558 is a reply to message #532539] Mon, 10 May 2010 08:48 Go to previous messageGo to next message
I am guessing, but it could be that the model does not define any
platform-configurations to validate against...
When are you seeing this error? When you try to open the model in the
editor?
- henrik
>> <?xml version="1.0" encoding="UTF-8"?>
>> </contributions>
> /Jesper
Re: b3 aggregator problem [message #532559 is a reply to message #532539] Mon, 10 May 2010 08:48 Go to previous messageGo to next message
It looks like you have not assigned any label to the "Aggregator" node (which is mandatory).
I guess you should see exact explanation of the problem in your error log.
Filip
>> </contributions>
> /Jesper
Re: b3 aggregator problem [message #532581 is a reply to message #532558] Mon, 10 May 2010 09:24 Go to previous messageGo to next message
On 2010-05-10 14:48, Henrik Lindberg wrote:
Yes, that seems to be it. Now it starts validating at least.
> editor?
No, when I try to build or validate the model.
/Jesper
Re: b3 aggregator problem [message #532788 is a reply to message #532581] Tue, 11 May 2010 04:52 Go to previous messageGo to next message
>> Hi,
After giving up an attempt to aggregate the entire Helios update site
which took forever :-), I tried this:
> <aggregator:Aggregator xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI" xmlns:aggregator="http://www.eclipse.org/b3/2010/aggregator/1.0.0" label="Helios p2 site">
> <configurations/>
> <configurations operatingSystem="linux" windowSystem="gtk"/>
> <repositories location="http://download.eclipse.org/releases/helios/">
> <products name="org.eclipse.sdk.ide"/>
> </repositories>
> <repositories location=" http://seupp-s-hemulen.ad.iar.com/ide_irp_storage/eclipse/up date-sites/cdt-master-7.0.0-I201003141308/"/>
> </contributions>
But then I get this non-informative error message:
> java.lang.NoSuchMethodError: org.eclipse.equinox.internal.p2.metadata.RequiredCapability. <init> (Ljava/lang/String;Ljava/lang/String;Lorg/eclipse/equinox/p2 /metadata/VersionRange;Lorg/eclipse/equinox/p2/metadata/expr ession/IMatchExpression;IIZLjava/lang/String;)V
/Jesper
Re: b3 aggregator problem [message #532808 is a reply to message #532788] Tue, 11 May 2010 05:39 Go to previous message
You need to upgrade your IDE to 3.6M7 (according to the error it looks like you are currently using 3.6M6).
Filip
>>> Hi,
>> <configurations/>
>> </repositories>
>> <repositories
>> </contributions>
Previous Topic:finding out dependencies when building a product
Next Topic:buckminster and p2 director behind a firewall ?
Current Time: Wed Jul 23 00:00:11 EDT 2025
Powered by FUDForum. Page generated in 0.25672 seconds
