Home » Modeling » Epsilon » ECL/EML example not working(Heterogeneous Model Merging)
ECL/EML example not working [message #532417] |
Sun, 09 May 2010 15:49  |
Hello Dimitrios,
This problem is similar to another one you were looking at:
http:// www.eclipse.org/forums/index.php?t=msg&th=161315&sta rt=0&
which does not seem to have been resolved, at least in the forum.
On Friday I did reinstalls of the latest Eclipse modeling package on two different Linux machines. Since then I have been trying to get the Heterogeneous Model Merging example to work on either.
Generally I get this error trace:
at org.antlr.runtime.CommonTokenStream.fillBuffer
at org.antlr.runtime.CommonTokenStream.LT
at org.eclipse.epsilon.eol.AbstractModule.invokeMainRule
at org.eclipse.epsilon.eol.AbstractModule.parse
at org.eclipse.epsilon.eml.dt.launching.
EmlLaunchConfigurationDelegate.launch
at org.eclipse.debug.internal.core.LaunchConfiguration.launch
at org.eclipse.debug.internal.ui.DebugUIPlugin.buildAndLaunch
at org.eclipse.debug.internal.ui.DebugUIPlugin$8.run
I say generally, because I actually did manage to get one successful run today. Thinking that changing the launch paths to use forward slashes was the secret, I tried the same thing from scratch only to find myself back at the above exception. Since then I have been unable to achieve any success, though I have downloaded and reinstalled the example numerous times.
Finally I tried running the ANT build that is part of the example with some modification: change "alias" to `alias` in the ECL, and remove the usematchtrace="eclMatchTrace" code from the compare and merge sections. Then, over the course of trying many other things the following rather bizarre pattern emerged:
1. Run the build:
Resource '/home/spokes/ExMerge/models/Source.model' does not exist.
2. Run the build:
Resource '/home/spokes/ExMerge/models/Vocabulary.model' does not exist.
3. Run the build:
4. Run the build:
Buildfile: /home/spokes/ExMerge/build.xml
loadModels:
compare:
merge:
disposeModels:
Resource '/home' does not exist.
Rinse, repeat. Same pattern every time. Note that I don't do anything between these steps. Also, step 4 doesn't actually ever change the Target.model file.
I don't expect you to answer for ANT, I only included that information in hopes that it helps you zero in on what's going on with Epsilon. Thanks for any help, I'm really keen on giving ECL a try.
--Steve
Re: ECL/EML example not working [message #532426 is a reply to message #532417] |
Sun, 09 May 2010 17:17   |
Hi Steve,
I'm afraid I can't reproduce this in my Windows box. I'll need to set up
Ubuntu using vmware and try to reproduce it there - but this will take
some time.
Dimitris
Stephen Barrett wrote:
> Hello Dimitrios,
> http://www.eclipse.org/forums/index.php?t=msg&th=161315& amp;start=0&
> at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
> numerous times.
> 1. Run the build:
> 2. Run the build:
> 3. Run the build:
> 4. Run the build:
> loadModels:
> compare:
> merge:
> disposeModels:
> Target.model file.
> --Steve
Re: ECL/EML example not working [message #532496 is a reply to message #532439] |
Mon, 10 May 2010 05:39   |
Hi Steve,
I've reproduced this. To run the example through the launch
configuration you need to change all \ to / in the paths of the .ecl and
..eml files. You'll also need to check out the
org.eclipse.epsilon.examples.metamodels project from the examples folder
in the SVN and right-click DomainVocabulary.ecore and Entity.ecore and
select "Register EPackages". I'll have a look at ANT now. Could you
please file a bug report using the link below?
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=GMT& component=Epsilon
Dimitris
> Some interesting details:
> I have now tried several other examples. Those that use EML, ECL, or EVL
> fail pretty much in the same way, i.e., when running the .launch file
> (after changing the source attribute of the configuration over to
> forward slashes) I get the same NullPointerException; while doing an ANT
> build (when there is a build.xml in the example) runs through the "fail
> on every model file before running successfully" pattern I noted in the
> first post. Additionally, it doesn't actually seem to create or alter
> anything.
> All examples that use EOL however, seem to work fine for me. Scanning
> the source code, I see that the launch method of the various
> LaunchConfigurationDelegate classes put together the name of the Epsilon
> file to be run slightly differently than the method for the EOL launch
> does. And it is the path of this file that I have to change in the run
> configuration to use the Unix style slashes.
> Beyond this point, I am over my head. So I will just have to wish you
> luck with it!
> --Steve
Spread the word: http://www.eclipse.org/gmt/epsilon/spreadtheword
Follow Epsilon on Twitter: http://twitter.com/epsilonews
Re: ECL/EML example not working [message #589013 is a reply to message #589006] |
Hi Steve,
Dimitris
> anything.
> luck with it!
> --Steve
Current Time: Sat Jul 26 08:07:23 EDT 2025
Powered by FUDForum. Page generated in 0.27999 seconds
