Home » Modeling » M2T (model-to-text transformation) » [XPAND/XTEND] defining aliases
[XPAND/XTEND] defining aliases [message #532458] Mon, 10 May 2010 03:27 Go to next message
for my m2t project I'm thinking about using aliases, which would depend on the language I generate code in.
As an exemple, if i were to generate SQL, I can't use the words "create", "table", "alter", "group" as names.
So I'm thinking of implementing a JAVA extension that will read a file with the aliases (unless someone has a better idea).
I will write that file in XML, and as the workflow is already written in XML, is there already a parser in the Xpand/Xtend project I could use, instead of writing my own ?
for the file, it will look like a succession of
<name value="create" replace="creates">
Maxime
Re: [XPAND/XTEND] defining aliases [message #532475 is a reply to message #532458] Mon, 10 May 2010 04:10 Go to previous messageGo to next message
Hi Maxime,
sorry, I don't get the point why you should not be able to use those names. Names that you choose within the model, for templates or whatever do not interfer with language concepts of the target language. The only names that you are don't allow to use are Xpand/Xtend keywords, and latter could also be escaped with ^. OK, "create" is such a conflicting keyword, so the escaping hint might be what you searched for.
~Karsten
Re: [XPAND/XTEND] defining aliases [message #532551 is a reply to message #532458] Mon, 10 May 2010 08:54 Go to previous messageGo to next message
using a metamodel I created, I generate SQL code.
So in my model, I should not use any of the SQL keywords, else when I try tu use the generated text, I'll get an error.
So I decided to create an extension, that will read a beforehand prepared file, and replace occurences in generated code (without modifying the model).
My question was, first is there something already implemented in the Xpand project to do this ?
Or, if not, is there a way to read xml files using Xpand (instead of using Sax, JDom, or StAx) ?
I thought there might already be a way to read an xml file, as the workflow is in xml.
Re: [XPAND/XTEND] defining aliases [message #533817 is a reply to message #532458] Mon, 17 May 2010 04:16 Go to previous message
I'll post my solution, in case it helps someone.
I'm using the Singleton Pattern.
using that xml file :
<option>
<package name="Company" value="company"/>
<package name="Site" value="company"/>
<package name="Group" value="user"/>
<package name="User" value="user"/>
<package name="Building" value="building"/>
</option>
And this Java file
package metamodel;
import java.io.*;
import org.jdom.*;
import org.jdom.input.*;
import java.util.List;
import java.util.Iterator;
public class Specific {
    private static org.jdom.Document document;
    private static Specific instance;
    private static Element racine;
    public static Specific getInstance(String name){
        if(null==instance){
            instance = new Specific(name);
        return instance;
    private Specific(String name){
        SAXBuilder sxb= new SAXBuilder();
            try {
                document = sxb.build(new File(name));
            } catch (JDOMException e) {
                System.out.println("Catched JDOMEXception");
            } catch (IOException e) {
                System.out.println("Catched IOException");
        racine = document.getRootElement();
    public static String getOption(String tag, String name){
        String result = name;
        List listOfTag = racine.getChildren(tag);
        Iterator i = listOfTag.iterator();
        while(i.hasNext()){
            Element elt = (Element) i.next();
            if(elt.getAttributeValue("name").equals(name)){
                result = elt.getAttributeValue("value");
                break;
        return result;
String alias(String name):
	getOption("alias", name);
String package(String name):
	getOption("package", name);
String getOption(String tag, String name) :
	JAVA metamodel.Specific.getOption(java.lang.String, java.lang.String);
String setInstance(String name):
	JAVA metamodel.Specific.getInstance(java.lang.String);
Now, at the start of my generation, I call getInstance, and load the xml file in memory.
During the text generation, the classes whose names are in file will be placed in package with given value.
Other classes will be placed in a package that has the class name.
Edit : I forgot the Xtend Extensions.
[Updated on: Mon, 17 May 2010 04:20] by Moderator
Previous Topic:Extend file
Next Topic:[Acceleo] Java application runner
Current Time: Sun Jul 27 08:11:59 EDT 2025
Powered by FUDForum. Page generated in 0.02748 seconds
