Home » Eclipse Projects » Remote Application Platform (RAP) » [Upload Widget] Access Denied?
[Upload Widget] Access Denied? [message #532384] Sun, 09 May 2010 09:01 Go to next message
Hi~~~
My clients told me that when using the Upload widget by selecting a file and clicking the "Upload" button, sometimes the RAP application UI will be directed to a page saying "Could not evaluate javascript response: Access Denied" immediately.
It is said that we can easily reproduce this problem by enable the code:uploadWidget.setData(WidgetUtil.CUSTOM_WIDGET_ID, "XXX"); but actually I just can't reproduce it no matter turning the code on on or off~~~
I googled this issue and most articles tell me that this kinda problem is mainly caused by crossing domain fied accessing.But It's really confusing cos I just can't see any probability that this kind of code would be there existing in the RAP framework.
So I wonder whether or not you have ever met this kinda error before?How can we solve or work arround it?
Thanks and Best Regards!
Tingel Christian
PS: This is what the error page says:
Access Denied
org.eclipse.swt.EventUtil.suspendEventHandling();var req = org.eclipse.swt.Request.getInstance();req.setRequestCounter( "37");var wm = org.eclipse.swt.Widget....BlahBlahBlah~~~
We are using RAP 1.2.0, this problem mostly occurs in IE6.
Thanks again~~~
Re: [Upload Widget] Access Denied? [message #533348 is a reply to message #532384] Thu, 13 May 2010 09:37 Go to previous messageGo to next message
Could somebody please give me some suggestion?I really appreciate that~~~
Tingel Christian
Re: [Upload Widget] Access Denied? [message #533478 is a reply to message #533348] Fri, 14 May 2010 03:57 Go to previous messageGo to next message
I don't have a IE6 running so I cannot try to reproduce this. Maybe you
can try to find out which JS call causes this problem by enabling the
debug mode and logging output.
VM-Params:
-Dorg.eclipse.rwt.clientLibraryVariant=DEBUG
-Dorg.eclipse.rwt.clientLogLevel=ALL
Stefan.
Tingel Christian schrieb:
> Tingel Christian
Re: [Upload Widget] Access Denied? [message #533494 is a reply to message #532384] Fri, 14 May 2010 05:18 Go to previous messageGo to next message
Hi Christian,
if you can come up with a snippet that reproduces the problem, please
file a bug. But, needless to say, without being able to reproduce, we
can't do anything.
Maybe the problem is related to your customers environment? For example,
is there a proxy? If IE-only, can you reproduce it with the same
Windows/Service Pack/IE version? ...
Regards, Ralf
Tingel Christian wrote:
> Hi~~~
> off~~~
> Tingel Christian
> Access Denied
> Thanks again~~~
Re: [Upload Widget] Access Denied? [message #533664 is a reply to message #532384] Sat, 15 May 2010 02:45 Go to previous messageGo to next message
Thanks an awful lot, Stefan and Ralf.
Yes, I can totally understand that it's impossible for you to tell how this problem happens without any snippets. I just meant to see if you had met this or this kind of problem before and if you have any suggestion on how to track this kinda problem
Thanks a lot for your suggestions and I will tell them to follow your directions and collect the information required, I will update this thread as soon as I get their feedback~~~
Thank you very much! Really appreciate that!
Best Regards!
Yours: Tingel Christian
Re: [Upload Widget] Access Denied? [message #538120 is a reply to message #532384] Sat, 05 June 2010 06:32 Go to previous messageGo to next message
Hi, Stefan and Ralf:
I have retrieved the feed back.The following is what the log says:
031031 DEBUG: org.eclipse.swt.Request[20]: sending request [ w1.focusControl=w40; uiRoot=w1; requestCounter=15; ]041046 DEBUG: org.eclipse.swt.Request[20]: sending request [ w1.focusControl=w40; uiRoot=w1; requestCounter=16; ]051453 DEBUG: org.eclipse.swt.Request[20]: sending request [ w1.focusControl=w40; uiRoot=w1; requestCounter=17; ]056828 DEBUG: org.eclipse.swt.Request[20]: sending request [ org.eclipse.swt.events.controlActivated=w94; w1.focusControl=null; uiRoot=w1; requestCounter=18; ]058359 DEBUG: org.eclipse.swt.Request[20]: sending request [ w94.path=ok.xls; w1.focusControl=null; uiRoot=w1; requestCounter=19; ]061046 DEBUG: org.eclipse.swt.Request[20]: sending request [ w1.focusControl=null; uiRoot=w1; requestCounter=20; ]071093 DEBUG: org.eclipse.swt.Request[20]: sending request [ w1.focusControl=null; uiRoot=w1; requestCounter=21; ]081171 DEBUG: org.eclipse.swt.Request[20]: sending request [ w1.focusControl=null; uiRoot=w1; requestCounter=22; ]086796 DEBUG: org.eclipse.swt.Request[20]: sending request [ w38.activeControl=testButton; org.eclipse.swt.events.widgetSelected=testButton; testButton.bounds.x=955; testButton.bounds.y=27; testButton.bounds.width=30; testButton.bounds.height=30; w1.focusControl=testButton; uiRoot=w1; requestCounter=23; ]086890 ERROR: org.eclipse.swt.Request[20]: Could not execute javascript: [org.eclipse.swt.EventUtil.suspendEventHandling();var req = org.eclipse.swt.Request.getInstance();req.setRequestCounter( "24" );var wm = org.eclipse.swt.WidgetManager.getInstance();var w = wm.findWidgetById( "w94" );w._performUpload();qx.ui.core.Widget.flushGlobalQueues();o rg.eclipse.swt.EventUtil.resumeEventHandling();]: TypeError - Access Denied. (#-2147024891)
Could you please give me some suggestion on how to use all these information to track the problem?
Tingel Christian
Re: [Upload Widget] Access Denied? [message #538315 is a reply to message #538120] Mon, 07 June 2010 06:24 Go to previous messageGo to next message
Hi Christian,
it seems that the function _performUpload in Upload.js can lead to a
TypeError with "Access Denied" message. I'd suggest to open a bug with
this trace and include information on know how to reproduce it.
Regards, Ralf
> Tingel Christian
Re: [Upload Widget] Access Denied? [message #538402 is a reply to message #532384] Mon, 07 June 2010 10:51 Go to previous message
Thanks Ralf~
Very sadly, I have tried to find the way follow which we can reproduce this problem for a whole night, but I can not even get close to it.
I really made the problem reproduced tonight, but it came so ocassionally that I could hardly catch it...
It seems that the frequency raises when there are 2 sessions accessing 2 different servers both of which provide file upload service with the Upload widget.
Would this be helpful if I file a bug using the above information plus the traces?
Thanks a lot and Best Regards!
Previous Topic:StartupPage.getBgImage throws Null Pointer
Next Topic:Text widget with default message needs a second click (IE)
Current Time: Sat Jul 26 19:59:54 EDT 2025
Powered by FUDForum. Page generated in 0.07605 seconds
