[Acceleo] Import a meta-model using its path [message #532199] |
Fri, 07 May 2010 09:56  |
I am writing an "mtl" generation template using a meta-model defined by a local Ecore file.
I would like to access the Ecore file by its path (since it's not registered in the NSUri), and I tried the following syntax :
[module generateEditor('/myproject/model/mymetamodel.ecore')/]
but it doesn't work (Acceleo can't find the metamodel).
Is Acceleo able to handle meta-models which are not registered in the NSUri ?
If that's not the case, how can I register a meta-model in the NSUri without launching a second Eclipse ?
PS : I am using the Acceleo 8.1 build.
Thanks in advance.
Re: [Acceleo] Import a meta-model using its path [message #533078 is a reply to message #532199] |
Wed, 12 May 2010 03:59  |
--------------030803090006010607000609
Hi Mehdi,
You should be able to use the NsURI of your ecore model directly, even
if it is within your workspace. Support of workspace metamodels has been
added to 3.0M5 though, so neither option (NsURI or path) will work with
a previous version (such as the 0.8.1 your using).
You either have to upgrade to Acceleo 3.0M7 or launch a runtime eclipse
as you suggest in the end of your mail.
Laurent Goubet
Obeo
labassim wrote:
> a local Ecore file.
> NSUri ?
> Thanks in advance.
name="laurent_goubet.vcf"
filename="laurent_goubet.vcf"
bjoyLjENCmVuZDp2Y2FyZA0KDQo=
--------------030803090006010607000609--
FUDForum. Page generated in 0.04647 seconds
