Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Video support using SWT(To display a video clip in Eclipse view)
Video support using SWT [message #531455] Wed, 05 May 2010 00:32 Go to next message
I have a view in eclipse where in I wish to show a clipping by handling pixel information. View initializes properly but fails to update in spite of setting new image to canvas.
I tried refreshing the view by hiding and showing the view where it updates the images properly but looses the smoothness.
Please provide any pointers.
Thanks in advance,
Vrushali.
Re: Video support using SWT [message #531752 is a reply to message #531455] Wed, 05 May 2010 23:39 Go to previous messageGo to next message
Can you provide us the snippet for recreating this problem ? That should
be helpful in determining the problem further.
Re: Video support using SWT [message #531767 is a reply to message #531752] Thu, 06 May 2010 02:15 Go to previous messageGo to next message
I'm suppose to display a video clipping so to mock I have restricted the scope to viewing 4 different images in view one by one after a particular interval.
Added paint and control listeners.
paintListener calls method paint.
for(int i=0;i<4;i++){
System.out.println("filename\t" + path + arr[i]);
loadImage(path + arr[i]);
try {
Thread.sleep(1000);
} catch (InterruptedException e) {
e.printStackTrace();
loadImage(String filename){
if (sourceImage != null && !sourceImage.isDisposed()) {
sourceImage.dispose();
sourceImage = null;
sourceImage = new Image(getDisplay(), filename);
private void paint(GC gc) {
Rectangle clientRect = getClientArea(); /* Canvas' painting area */
if (sourceImage != null) {
Rectangle imageRect =
SWT2Dutil.inverseTransformRect(transform, clientRect);
int gap = 2; /* find a better start point to render */
imageRect.x -= gap; imageRect.y -= gap;
imageRect.width += 2 * gap; imageRect.height += 2 * gap;
Rectangle imageBound = sourceImage.getBounds();
imageRect = imageRect.intersection(imageBound);
Rectangle destRect = SWT2Dutil.transformRect(transform, imageRect);
if (screenImage != null)
screenImage.dispose();
screenImage =
new Image(getDisplay(), clientRect.width, clientRect.height);
GC newGC = new GC(screenImage);
newGC.setClipping(clientRect);
newGC.drawImage(
sourceImage,
imageRect.x,
imageRect.y,
imageRect.width,
imageRect.height,
destRect.x,
destRect.y,
destRect.width,
destRect.height);
newGC.dispose();
gc.drawImage(screenImage, 0, 0);
System.out.println("updated");
} else {
gc.setClipping(clientRect);
gc.fillRectangle(clientRect);
initScrollBars();
If I debug, value of images changes correctly but fail to update view with those images. It directly shows last image out of those 4 images.
Please help with some pointers. Stuck badly.
Thanks a lot in advance,
Vrushali.
Re: Video support using SWT [message #532158 is a reply to message #531767] Fri, 07 May 2010 07:15 Go to previous message
May be this snippet for showing animated gif will help you
http://dev.eclipse.org/viewcvs/index.cgi/~checkout~/org.ecli pse.swt.snippets/src/org/eclipse/swt/snippets/Snippet141.jav a
(Its very unusual to have same question in a forum from different users Tomas has also the same questions,are you guys working on the same thing?)
Previous Topic:Fasted way to display images?
Next Topic:SWT Table
Current Time: Sat Jul 19 04:43:50 EDT 2025
Powered by FUDForum. Page generated in 0.03912 seconds
