Home » Eclipse Projects » Remote Application Platform (RAP) » The JobManager's lock question
The JobManager's lock question [message #532072] Fri, 07 May 2010 00:59 Go to next message
I run a test that using the Job, and I find that when mutil user will wait for the JobManger's global lock, and so the UIThread is blocked, so can I change the JobManager's source to extend SessionSingletonBase, and in this case, means one user one JobManager's lock, so mutil user will not wait the global lock.
Is this solution will resolve the mutil user wait for lock's problem?
Re: The JobManager's lock question [message #532126 is a reply to message #532072] Fri, 07 May 2010 05:11 Go to previous messageGo to next message
we recently solved this bug:
283490: Display.syncExec() leads to deadlock
https://bugs.eclipse.org/bugs/show_bug.cgi?id=283490
With these changes, the described problem shouldn't occur any more. If
you still experience problems, please file a bugzilla with standalone
code to reproduce.
BTW, making the JobManager a session-singleton would make Jobs that are
session-independent impossible and hence isn't an option.
Rüdiger
Rüdiger Herrmann
http://eclipsesource.com
Re: The JobManager's lock question [message #532127 is a reply to message #532072] Fri, 07 May 2010 05:29 Go to previous message
thanks, I will checkout and test again!
Previous Topic:[ANN] RAP 1.3 M7
Next Topic:StartupPage.getBgImage throws Null Pointer
Current Time: Wed Jul 30 07:34:45 EDT 2025
Powered by FUDForum. Page generated in 0.06089 seconds
