unmet dependencies on installing PDT [SOLVED] [message #531888] |
Thu, 06 May 2010 09:26  |
Ubuntu 10.04 ( recent upgrade to lucid)
I can install exclipse (3.5.2) from the Ubuntu repository , but when I try to add PDT according to
http://wiki.eclipse.org/PDT/Installation#From_Update_Site
it tells me this :
Cannot complete the install because one or more required items could not be found.
Software being installed: PHP Development Tools (PDT) Runtime Feature 2.2.0.v201004270700-7L7J-F8NcJTJJwdOKOJJ (org.eclipse.php.feature.group 2.2.0.v201004270700-7L7J-F8NcJTJJwdOKOJJ)
Missing requirement: Dynamic Languages Toolkit - Core Frameworks 2.0.0.v20100505-1154-7L--EAAoOUVSNc7Bb2w0 (org.eclipse.dltk.core.feature.group 2.0.0.v20100505-1154-7L--EAAoOUVSNc7Bb2w0) requires 'org.eclipse.emf.ecore.feature.group 2.4.0' but it could not be found
Cannot satisfy dependency:
From: PHP Development Tools (PDT) Runtime Feature 2.2.0.v201004270700-7L7J-F8NcJTJJwdOKOJJ (org.eclipse.php.feature.group 2.2.0.v201004270700-7L7J-F8NcJTJJwdOKOJJ)
To: org.eclipse.dltk.core.feature.group [2.0.0,3.0.0)
What am I missing ?
[Updated on: Sat, 08 May 2010 07:09] by Moderator
Re: unmet dependencies on installing PDT [message #532125 is a reply to message #531888] |
Fri, 07 May 2010 05:12   |
ive got the sun jdk
$ sudo aptitude show sun-java6-jdk
Package: sun-java6-jdk
State: installed
Automatically installed: no
Version: 6.20dlj-1ubuntu3
Priority: optional
Section: java
Maintainer: Debian Java Maintainers <pkg-java-maintainers@lists.alioth.debian.org>
Uncompressed Size: 62.5M
Depends: sun-java6-bin (>= 6.20dlj-1ubuntu3), libc6, libx11-6
PreDepends: debconf (>= 0.5) | debconf-2.0
Suggests: sun-java6-demo, openjdk-6-doc, sun-java6-source
Provides: java-compiler, java-sdk, java2-compiler, java2-sdk, java5-sdk, java6-sdk
Description: Sun Java(TM) Development Kit (JDK) 6
The JDK(TM) is a development environment for building applications, applets, and components using the Java programming language.
The JDK includes tools useful for developing and testing programs written in the Java programming language and running on the Java Platform.
NOTE: You must accept Sun's EULA prior to successfully installing this package
paul@zimmy-desktop:/usr/lib/jvm/java-6-sun-1.6.0.20/bin$
and configured eclipse.ini
-startup
plugins/org.eclipse.equinox.launcher_1.0.201.R35x_v20090715. jar
--launcher.library
plugins/org.eclipse.equinox.launcher.gtk.linux.x86_64_1.0.20 0.v20090519
-product
org.eclipse.epp.package.php.product
-showsplash
org.eclipse.platform
--launcher.XXMaxPermSize
256m
-vm
/usr/lib/jvm/java-6-sun-1.6.0.20/bin/java
-vmargs
-Dosgi.requiredJavaVersion=1.5
-XX:MaxPermSize=256m
-Xms40m
-Xmx256m
/home/paul/eclipse/eclipse.ini
and its here
paul@zimmy-desktop:/$ ls /usr/lib/jvm/java-6-sun-1.6.0.20/bin/
appletviewer HtmlConverter jarsigner javah jconsole jinfo jsadebugd jvisualvm pack200 rmiregistry tnameserv xjc
apt i386 java javap jcontrol jmap jstack keytool policytool schemagen unpack200
ControlPanel idlj javac java-rmi.cgi jdb jps jstat native2ascii rmic serialver wsgen
extcheck jar javadoc javaws jhat jrunscript jstatd orbd rmid servertool wsimport
and get this
paul@zimmy-desktop:~/eclipse$ java eclipse -vm /usr/lib/jvm/java-6-sun-1.6.0.20/bin/java
Exception in thread "main" java.lang.NoClassDefFoundError: eclipse
Caused by: java.lang.ClassNotFoundException: eclipse
at java.net.URLClassLoader$1.run(URLClassLoader.java:217)
at java.net.URLClassLoader.findClass(URLClassLoader.java:205)
at java.lang.ClassLoader.loadClass(ClassLoader.java:321)
at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:294 )
at java.lang.ClassLoader.loadClass(ClassLoader.java:266)
at java.lang.ClassLoader.loadClassInternal(ClassLoader.java:334 )
Could not find the main class: eclipse. Program will exit.
thanks f or any pointers
Re: unmet dependencies on installing PDT [message #532252 is a reply to message #532125] |
Fri, 07 May 2010 12:53   |
"p cooper" <paul@medalto.co.uk> wrote in message
news:hs0lij$ajv$1@build.eclipse.org...
> ive got the sun jdk
> State: installed
> Priority: optional
> Section: java
> <mailto:pkg-java-maintainers@lists.alioth.debian.org>
> java6-sdk
> package
> mailto:paul@zimmy-desktop:/usr/lib/jvm/java-6-sun-1.6.0.20/bin$
> -startup
> --launcher.library
> -product
> -showsplash
> 256m
> -vm
> -vmargs
> -Xms40m
> -Xmx256m
> /home/paul/eclipse/eclipse.ini and its here
> mailto:paul@zimmy-desktop:/$ ls /usr/lib/jvm/java-6-sun-1.6.0.20/bin/
> and get this
> mailto:paul@zimmy-desktop:~/eclipse$ java eclipse -vm
> at java.security.AccessController.doPrivileged(Native Method)
> mailto:paul@zimmy-desktop:~/eclipse$ thanks f or any pointers
You don't want to run 'java eclipse ...' To launch Eclipse, you run the
eclipse executable. It should be in the root directory where you extracted
the Eclipse tar file. Change directory this directory and run eclipse.
cd {Directory were Eclipse extracted}
eclipse (run this if '.' is in your path)
../eclipse (run this if '.' isn't in your path)
FUDForum. Page generated in 0.07856 seconds
