Home » Archived » Buckminster » Director-installed headless buckminster broken on OSX
Director-installed headless buckminster broken on OSX [message #532064] Thu, 06 May 2010 21:56 Go to next message
I'm getting started with Buckminster and am running into problems on
OSX/Cocoa/x86-64. I'm wondering if anyone else is running into this
and/or if this is a known issue.
Basically I follow the steps in the docs -- download
director_latest.zip, use it to install buckminster (from the 3.6
headless site), then install additional features into it.
The problem is, the buckminster product is incorrectly installed -- when
I run it I get errors "acquiring the application service". At least one
problem is the fact that config.ini doesn't specify the application to run.
I didn't dig deeper (yet), but I confirmed that everything works fine on
Linux/GTK/x86.
Am missing something or is this a new/existing bug? Thanks.
--Peter
Re: Director-installed headless buckminster broken on OSX [message #532101 is a reply to message #532064] Fri, 07 May 2010 04:02 Go to previous messageGo to next message
Hi Peter,
maybe this helps you:
http://www.eclipse.org/forums/index.php?t=tree&goto=5172 30&
Johannes
Re: Director-installed headless buckminster broken on OSX [message #532232 is a reply to message #532101] Fri, 07 May 2010 11:27 Go to previous message
Sweet, that did it, thanks!
On 5/7/10 4:02 AM, Johannes Utzig wrote:
> Hi Peter,
> Best regards,
> Johannes
Previous Topic:create.product action not finding the IU
Next Topic:site.p2.zip action does not produce zipped site in Hudson
Current Time: Wed Jun 18 02:53:36 EDT 2025
Powered by FUDForum. Page generated in 0.04068 seconds
