Home » Archived » Buckminster » create.product action not finding the IU
create.product action not finding the IU [message #531855] |
Thu, 06 May 2010 07:45  |
I'm trying to follow the layout in the
org.eclipse.buckminster.tutorial.mailapp projects to build an RCP, but
the "create.product" action fails to find the IU. In the tutorial
projects, the "iu" attribute in
o.e.b.t.mailapp.product.feature/buckminster.cspec is set to
"org.eclipse.buckminster.tutorial.mailapp.product". I've tried to follow
the exact same naming convention, but with "com.iar.hubble" instead of
"org.eclipse.buckminster.tutorial.mailapp". Therefore, I set the "iu"
attribute to "com.iar.hubble.product", but when executing the
"create.product" action, I get the following error:
> [ant] C:\buckminster-3.6\plugins\org.eclipse.equinox.launcher_1.1. 0.v20100322-1720.jar
> [ant] file:/C:/Users/JESPER~1.IAR/AppData/Local/Temp/buckminster/b uild/com.iar.hubble.product.feature_1.0.0-eclipse.feature/si te.p2/
> [ant] C:\Users\JESPER~1.IAR\AppData\Local\Temp\buckminster\build\c om.iar.hubble.product.feature_1.0.0-eclipse.feature\Hubble
> [ant] The installable unit com.iar.hubble.product has not been found.
> [ant] Application failed, log file location: C:\buckminster-3.6\configuration\1273146099416.log
> ERROR: org.eclipse.core.runtime.CoreException: C:\work\tmpws\features\com.iar.hubble.product.feature\build\ product.ant:22: Java returned: 13
I've tried a bunch of different values for the iu attribute, but nothing
seems to stick.
/Jesper
Re: create.product action not finding the IU [message #531862 is a reply to message #531855] |
Thu, 06 May 2010 08:05   |
Hi Jesper,
Where do you keep the .product definition for this product? In what project and what type of project? What ID does the
product have there.
- thomas
>> [ant]
>> [ant]
>> [ant]
>> Java returned: 13
> seems to stick.
Re: create.product action not finding the IU [message #532115 is a reply to message #532112] |
Fri, 07 May 2010 04:48   |
On 05/07/2010 10:33 AM, Jesper Eskilson wrote:
> On 2010-05-07 08:02, Thomas Hallgren wrote:
>> Are you creating the actual update site from the product feature?
> Yes.
>> You should know that the feature that defines the content of the actual
>> site normally is excluded from the site itself. You can change this
>> behavior by adding the property:
>> site.include.top=true
> Just to clarify, this properties should go into the build.properties
> file in the product feature (com.iar.hubble.product.feature in my case),
> right?
Not really. The important thing is that the property is passed on when you perform the site.p2 action. Either as a
-Dxxx=yyy or as a -P <property file>
>> or, add a feature that describes the site (gives the site a name, lists
>> its content etc.) and include the product feature there.
> I tried to set the site.include.top attribute to true, but it still
> fails. I'm not really sure what the "iu" attribute is supposed to refer
> to. Should it name the product feature name
> (com.iar.hubble.product.feature)? In the tutorial projects it is set to
> "org.eclipse.buckminster.tutorial.mailapp.product", but that is not the
> name of the product feature.
It should appoint the product. Not the feature. 'com.iar.hubble.product' seems correct to me.
> And how does the create.product action know which product definition
> file to use (i.e. "hubble.product" in my case, and "testmailapp.product"
> in the tutorial)?
It doesn't use the product definition file directly.
When you generate a p2 repository, the publisher will generate UI's for all product definitions that it finds in the
included features. The create.product calls the p2 director to make an install from the generated repository. The
director in turn, requests the product IU.
- thomas
Re: create.product action not finding the IU [message #532117 is a reply to message #532112] |
Fri, 07 May 2010 04:49   |
Hi Jesper,
please see comments inline.
> right?
No, it's not part of the build properties. It's a property evaluated by
the buckminster runtime. If you invoke your action from the UI the
dialog gives you an option to specify a properties file. If you run
headless you can add a -p some/file.properties.
Just create a buckminster.properties or so and add the line
iu means Installable Unit. An installable unit in the p2 sense can for
example be a bundle, a feature, or a complete product. In your case the
IU is a complete product, hence, the ID of the IU is the ID of the
product as it's displayed in the overview section when you open your
product file.
> in the tutorial)?
The create.product action does not process any product files, it just
invokes the p2 director that will assemble your product. It tells the
director which IU you want to install and where to get the materials
from (the p2 repository that your site.p2 action created earlier).
Johannes
Re: create.product action not finding the IU [message #532130 is a reply to message #532117] |
Fri, 07 May 2010 05:16   |
On 2010-05-07 10:49, Johannes Utzig wrote:
> Hi Jesper,
>> right?
> product file.
>> in the tutorial)?
Do I need to tell Buckminster where the p2 site is located when
executing the create.product action? Judging by the debug output, it
looks as if the actual p2 site used is in a different place than the
buckminster.output.root directory I set in the buckminster.properties file.
Is there a way to display all the IUs, including any products, in an
update site? The "listsite" command only displays the features.
/Jesper
Re: create.product action not finding the IU [message #532151 is a reply to message #532131] |
Fri, 07 May 2010 06:46  |
> The b3 aggregator (former buckminster aggregator) should show you all
> IUs of a p2 repository.
This solved the problem. (The b3 aggregator was very helpful.) My
product ID was "com.iar.hubble", as stated in the "hubble.product" file
(and not com.iar.hubble.product", as I had set the iu property to).
Now I only have the "One or more certificates rejected" problem to deal
with, but that is another issue.
Thanks alot!
/Jesper
Current Time: Sat Jul 26 12:52:40 EDT 2025
Powered by FUDForum. Page generated in 0.04665 seconds
