Re: Missing element in XML editor autocompletion [message #531806] |
Thu, 06 May 2010 05:23  |
Arnaud,
The WTP project provides the editor, so I'm redirecting your post to
their newsgroup/forum.
Arnaud wrote:
> In the following xml file:
> <tst:root
> xmlns:ext="testExt:/test/xsd/validation"
> xmlns:tst="test:/test/xsd/validation"
> <tst:positiveComment/>
> </tst:root>
> only tst:positiveComment and tst:negativeComment take part of eclipse
> XML editor Ctrl+Space auto completion. The element 'ext:extComment'
> is not proposed...
> Is there something wrong in my configuration ?
> Both xsd schema are 'defined' using catalogContributions extension point:
> <extension point="org.eclipse.wst.xml.core.catalogContributions">
> <catalogContribution id="myId"> <public
> publicId="test:/test/xsd/validation"
> uri="xsd/test.xsd">
> </public>
> <public
> publicId="testExt:/test/xsd/validation"
> uri="xsd/test_ext.xsd">
> </public>
> </catalogContribution> </extension>
> text.xsd file is:
> <?xml version="1.0" encoding="UTF-8"?> <xsd:schema
> xmlns:xsd="http://www.w3.org/2001/XMLSchema"
> elementFormDefault="qualified"
> attributeFormDefault="unqualified"
> targetNamespace="test:/test/xsd/validation"
> xmlns:tst="test:/test/xsd/validation">
> <xsd:element name="root">
> <xsd:complexType> <xsd:choice minOccurs="0"
> maxOccurs="unbounded"> <xsd:element ref="tst:comment" />
> </xsd:choice> </xsd:complexType> </xsd:element>
> <xsd:complexType name="CommentType" >
> </xsd:complexType>
> <!-- test abstract element and subs.group :: WORKS -->
> <xsd:element name="comment" type="tst:CommentType" abstract="true" />
> <xsd:element name="positiveComment" type="tst:CommentType"
> substitutionGroup="tst:comment" />
> <xsd:element name="negativeComment" type="tst:CommentType"
> </xsd:schema>
> and test_ext.xsd is:
> targetNamespace="testExt:/test/xsd/validation"
> <xsd:import namespace="test:/test/xsd/validation" />
> <!-- define a new comment type in substitution group -->
> <xsd:element name="extComment" type="tst:CommentType"
> substitutionGroup="tst:comment" >
> <xsd:annotation><xsd:documentation xml:lang="en">
> This kind of comment is defined in another xsd file...
> </xsd:documentation></xsd:annotation> </xsd:element>
> </xsd:schema>
> I suspect XML editor doesn't take care of imported substitutionGroup
> element. ? is it possible ?
> In other hand I can add manually '<ext:extComment/>' after
> positiveComment, then Validate command return No errors
> (meaning test_ext.xsd is known and parsed correctly).
> Any suggestion to add 'ext:extComment' in editor proposals ?
> Thanks for your help,
> Arnaud.
Re: Missing element in XML editor autocompletion [message #532247 is a reply to message #532121] |
Fri, 07 May 2010 12:30  |
Hi Arnaud, yes, I worked on a solution when the bug was opened but the
problem is complex and at the time it seemed to me that the risks of
breaking existing function outweighed the benefits. Time permitting I'll try
to take a look at it again. Let's continue the conversation in the bugzilla.
Valentin
"Arnaud" <ademuyser@fr.ibm.com> wrote in message
news:hs0l50$p6o$1@build.eclipse.org...
> Hi Valentin,
> Thanks for the answer.
> Yes it seems to be same kind of problem described in
> https://bugs.eclipse.org/bugs/show_bug.cgi?id=247312
> The :cry: sad news is the patch to fix the issue was made last year but
> not finished/pushed into WTP. SO I haven't a chance to get issue fixed in
> next (few) release.
> Arnaud.
FUDForum. Page generated in 0.03277 seconds
