Home » Eclipse Projects » EclipseLink » CreateNativeQuery ResultSet mapping
CreateNativeQuery ResultSet mapping [message #531509] Wed, 05 May 2010 05:40 Go to next message
I have problem running native query. The getSingleResult fills only datum filed and the ks field is always null. No exception is thrown. Can anybody help?
Pavel
private Stat getExpediceData(Vykladka vykladka, Date datum)
         queryString = "select datum, ks from vykaz v join expedice e on v.idexpedice=e.idexpedice where e.datum = ? and v.idvykladka=?";
        Query q = em.createNativeQuery(queryString, Stat.class);
        q.setParameter(1, datum, TemporalType.DATE);
        q.setParameter(2, vykladka.getIdvykladka());
        Stat stat = (Stat) q.getSingleResult();
        return stat;
@Entity
public class Stat implements Serializable {
    @Id
    @Temporal(TemporalType.DATE)
    @Column(name = "datum")
    private Date datum;
    @Column(name = "ks")
    private Integer ks;
    @Column(name = "remitenda")
    private Integer remitenda;
    @Column(name = "cas_zavozu")
    private String casZavozu;
    getters and setters
Re: CreateNativeQuery ResultSet mapping [message #531961 is a reply to message #531509] Thu, 06 May 2010 11:25 Go to previous messageGo to next message
Probably a case issue. Try using upper case in your @Column and SQL.
What database are you using?
Re: CreateNativeQuery ResultSet mapping [message #532078 is a reply to message #531961] Fri, 07 May 2010 02:01 Go to previous messageGo to next message
James wrote on Thu, 06 May 2010 11:25
Uppercase didn't help. The database is MS SQL2000.
Re: CreateNativeQuery ResultSet mapping [message #532153 is a reply to message #532078] Fri, 07 May 2010 07:08 Go to previous messageGo to next message
I think the problem is in resultset mapping. If I parse the resultset (see code below) then I see the expected values.
But I still don't know where the problem is. Any idea?
private Stat getExpediceData(Vykladka vykladka, Date datum) {
        String queryString = "select datum, ks from vykaz v join expedice e on v.idexpedice=e.idexpedice where e.datum = ? and v.idvykladka=?";
        Query q = em.createNativeQuery(queryString);
        List<Object[]> result = q.getResultList();
        for (Object[] o : result){
            System.out.println(o[0]);
            System.out.println(o[1]);
Re: CreateNativeQuery ResultSet mapping [message #532276 is a reply to message #532153] Fri, 07 May 2010 14:35 Go to previous messageGo to next message
Native queries that return entities will return managed entities. Could the entities being queried exist in the cache or already be managed? Try to use the em.find api to return a Stat entity that would be returned and see if it has the ks field set or not. If it is null, then you will need to see why entities are being returned only partially populated - some users mistakenly use native queries to return entities but do not select all the fields, corrupting the cache with partially populated entities.
Best Regards,
Chris
Re: CreateNativeQuery ResultSet mapping [message #532375 is a reply to message #532276] Sun, 09 May 2010 05:22 Go to previous message
Thanks Chris you were right. There already were entities with datum field filled only. So I made some code change and used QueryHints.REFRESH and now everything works.
So many thanks for help to all.
Previous Topic:dynamically configure javax.persistence.jdbc.url?
Next Topic:Is it possible to run a @TableGenerator in a separate transaction?
Current Time: Fri Jul 25 22:42:38 EDT 2025
Powered by FUDForum. Page generated in 0.05015 seconds
