perspectiveExtension - how order provided views [message #531051] |
Mon, 03 May 2010 10:19  |
I have this configuration of several plug ins, lets say A, B, C and D. A is declaring a perspective with a folder layout with a view. B, C, D are all providing their own views into that perspective via the perspectiveExtension EP.
I need a way to specify the order of the views provided by B, C and D relative to each oder. It does not work with the "relative" attribute because the view to which you relate has to be already in the folder...
Any ideas about a workaround? Setting placeholders on the folder layout does not seem to work either...
I could create several EP similar to the perspectiveExtension to provide the view ID-s and add the views manually based on the EP on which they are attached. But I would still want to allow other plugins to attach views via the perspectiveExtension EP... before my views in B, C and D....
FUDForum. Page generated in 0.03538 seconds
