Home » Modeling » M2T (model-to-text transformation) » [Check] Location of ECORE model influences validity of check files?
[Check] Location of ECORE model influences validity of check files? [message #531027] Mon, 03 May 2010 08:38 Go to next message
Originally posted by: ML1984.gmx.de
Hello everybody.
Our check files show 'type not found' errors (editor & problems view),
if the referenced meta model is not in the same plugin project as the
check files are.
Is this a bug or a feature?
There is a plugin dependency between these two projects, but it does not
work either.
Mark
PS. I am using Eclipse Modeling Tools SR2.
Re: [Check] Location of ECORE model influences validity of check files? [message #531049 is a reply to message #531027] Mon, 03 May 2010 10:05 Go to previous messageGo to next message
Having a plugin dependency is the way to go, so this is most likely a bug. However, I do not experience this behavior.
If you want this bug processed then please open a bugzilla report and attach a reproducing example project.
Kind regards,
~Karsten
Re: [Check] Location of ECORE model influences validity of check files? [message #531261 is a reply to message #531049] Tue, 04 May 2010 07:06 Go to previous message
Hi Karsten,
Ive got the same problem,
https://bugs.eclipse.org/bugs/show_bug.cgi?id=303069
mahmoud
Previous Topic:[xtend] renameOperation
Next Topic:[XPand dev] Tracing model access
Current Time: Wed Jul 30 16:39:08 EDT 2025
Powered by FUDForum. Page generated in 0.05496 seconds
