Home » Modeling » EMF » Retain original resource reference when copying entries between feature maps
Retain original resource reference when copying entries between feature maps [message #531162] Mon, 03 May 2010 19:41 Go to next message
I am loading in arbitrary XML content using the GenericXMLResourceFactoryImpl and URIConverter.ReadableInputStream:
Resource.Factory factory = new GenericXMLResourceFactoryImpl();
XMLResource resource = (XMLResource) factory.createResource(null);
resource.load(new URIConverter.ReadableInputStream("<text>" + xmlString + "</text>"), null);
XMLTypeDocumentRoot root = (XMLTypeDocumentRoot) resource.getContents().get(0);
AnyType value = (AnyType) root.getMixed().getValue(0);
Then I am adding the entries from value.getMixed() to a new FeatureMap that is part of an EObject graph that was created programmatically (not yet contained in a Resource).
XYZClass obj = XYZFactory.eINSTANCE.createXYZClass();
obj.getMixed().addAll(value.getMixed());
assert value.eResource != null; // not here
// ... return from method
// ... do some other things
assert value.eResource == null; // here it is null
What I am noticing is that at some point value.eResource() gets set to null. What can I do to retain this original resource as long as possible (until obj gets added to a different resource)? What mechanism is clearing out the reference from value to its original resource?
JT
Re: Retain original resource reference when copying entries between feature maps [message #531246 is a reply to message #531162] Tue, 04 May 2010 06:14 Go to previous message
John,
Comments below.
You can't. Once you remove the object from the document root that's in
a resource to a document root that's not in a resource then your object
is no longer in a resource.
> original resource?
Making the value be contained as a child of another object will do
that. I.e., when the eContainer changes.
> JT
Previous Topic:[CDO] CDOFeatureDelta => ADD with null
Next Topic:Generic TreeView Editor just show attribute "name"
Current Time: Thu Jul 24 02:41:54 EDT 2025
Powered by FUDForum. Page generated in 0.04231 seconds
