Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Running Swing or AWT widgets within SWT.
Running Swing or AWT widgets within SWT. [message #531018] Mon, 03 May 2010 08:08 Go to next message
I have an AWT application, which uses a JFrame as top container. I want to hook this app to work from within an SWT Shell - like from a command or an editor.
I know how to get to the Shell of the editor view.
Perhaps I should hook the main Composite component of this JFrame?
Is this possible at all? What is the trick?
- Uri
Re: Running Swing or AWT widgets within SWT. [message #531029 is a reply to message #531018] Mon, 03 May 2010 08:17 Go to previous messageGo to next message
> or an editor. I know how to get to the Shell of the editor view. Perhaps
> I should hook the main Composite component of this JFrame? Is this
Check out the SWT_AWT bridge at http://www.eclipse.org/swt/snippets/
you can embed your Swing/AWT components in a Composite, i.e. in a view
or in an editor.
It sounds like you need a heavy-weight component (AWT) as the root and
then add the lightweight components underneath. See
org.eclipse.swt.awt.SWT_AWT.new_Frame(Composite)
PW
Paul Webster
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/guide/workbench.htm
Re: Running Swing or AWT widgets within SWT. [message #531074 is a reply to message #531029] Mon, 03 May 2010 11:44 Go to previous messageGo to next message
Many thanks.
I looked at Snippet135 and made out of it something simpler which only shows the Shell, but not the label inside - what is missing there?
package tests;
 * example snippet: embed Swing/AWT in SWT
 * For a list of all SWT example snippets see
 * http://www.eclipse.org/swt/snippets/
 * @since 3.0
import org.eclipse.swt.SWT;
import org.eclipse.swt.awt.SWT_AWT;
import org.eclipse.swt.widgets.Composite;
import org.eclipse.swt.widgets.Shell;
public class BridgeSnippet {
		final Display display = new Display();
		final Shell shell = new Shell(display);
		shell.setText("SWT and Swing/AWT Example");
		Composite composit = new Composite(shell, SWT.EMBEDDED);
		java.awt.Frame frame = SWT_AWT.new_Frame(composit);
		frame.setTitle("AWT Frame");
		java.awt.Label label = new java.awt.Label("Hello world");
		frame.add(label);
		composit.setVisible(true);
		shell.open();
		while(!shell.isDisposed()) {
			if (!display.readAndDispatch()) display.sleep();
		display.dispose();
Re: Running Swing or AWT widgets within SWT. [message #531104 is a reply to message #531074] Mon, 03 May 2010 13:24 Go to previous messageGo to next message
Uri Shani wrote:
> Many thanks.
You need to set layouts on your shell and composite. Even a FillLayout
will display the label.
PW
Paul Webster
Re: Running Swing or AWT widgets within SWT. [message #531133 is a reply to message #531104] Mon, 03 May 2010 16:05 Go to previous message
Many, many thanks... working now.
- Uri Razz
Previous Topic:AutoSizing the Tree Columns
Next Topic:Is it possible to use combo with cascade behavior ?
Current Time: Wed Jul 23 20:32:20 EDT 2025
Powered by FUDForum. Page generated in 0.04294 seconds
