Home » Eclipse Projects » EclipseLink » Mapping two objects on same table
Mapping two objects on same table [message #528692] Wed, 21 April 2010 09:52 Go to next message
I m working on a legacy database. I m encountering the following problem, there is two classes mapped into a single table. The only way to differentiate them is their id.
The Id of each of thel belongs to two differents sequences.
Example :
create table Objet ( ID number (10), value varchar2(50), value2 varchar2(50) );
create sequence seq1 start with 1 increment by 1 maxvalue 199;
create sequence seq2 start with 200 increment by 1 maxvalue 299;
I have two classes one corresponding to the value of the first sequence and the other to second one. these two classes do not belong to same hierarchy
I m using JPA 1.0 based on eclipselink 1.0.2.
I can not find a way to do this, can you help me?
X
[Updated on: Wed, 21 April 2010 09:54] by Moderator
Re: Mapping two objects on same table [message #528939 is a reply to message #528692] Thu, 22 April 2010 09:18 Go to previous messageGo to next message
I very odd design. You might consider having one class, or two tables.
You could map this in EclipseLink. You could set an additionalJoinExpression on the two classes where the id < 200, and id >= 200. You would need to do this in code, using a DescriptorCustomizer.
public void customize(ClassDescriptor descriptor) {
descriptor.getQueryManager().setAdditionalJoinExpression(... );
Re: Mapping two objects on same table [message #531050 is a reply to message #528692] Mon, 03 May 2010 10:08 Go to previous messageGo to next message
is it so weird ? Laughing
Re: Mapping two objects on same table [message #531061 is a reply to message #528939] Mon, 03 May 2010 10:40 Go to previous messageGo to next message
I ve already tried this but it doesn't work for basic operation. Eclipselink doesn't add the addionnal join. I did not forget to add the @Customizer annotation to the class.
Do you have any idea ?
Re: Mapping two objects on same table [message #531073 is a reply to message #528692] Mon, 03 May 2010 11:32 Go to previous messageGo to next message
The additionalJoinExpression will be added to any query operation.
Re: Mapping two objects on same table [message #531800 is a reply to message #531073] Thu, 06 May 2010 05:11 Go to previous message
Cool it's working, thanks a lot for your help.
Previous Topic:JPA entities returned from WebService
Next Topic:JPA Questions
Current Time: Sun Jul 27 02:07:39 EDT 2025
Powered by FUDForum. Page generated in 0.03923 seconds
