Home » Newcomers » Newcomers » Getting started with RAP
Getting started with RAP [message #530957] Mon, 03 May 2010 03:58 Go to next message
Hi All,
I am trying to start off with RAP.I updated the plug-ins from this update site http://www.eclipse.org/rap/downloads/.
I updated the tooling.It says it includes the runtime also.
I even tried Helios release of RCP/RAP IDE.
In both i am getting the same issue.I am not able to resolve IEntryPoint.I think it belongs to org.eclipse.rap.ui, which i am not able to find in the installed plug-ins.
Please help.
Thanks and Regards,
Saurav
Re: Getting started with RAP [message #530988 is a reply to message #530957] Mon, 03 May 2010 05:19 Go to previous messageGo to next message
Saurav,
It's best to ask about RAP on the RAP newsgroup/forum, which I've added
to the "to" list of this reply. Have you created new plugins with
dependencies on the plugin that contains the IEntryPoint interface?
saurav wrote:
> Hi All,
> Please help.
> Thanks and Regards,
> Saurav
Re: Getting started with RAP [message #531008 is a reply to message #530988] Mon, 03 May 2010 07:16 Go to previous messageGo to next message
Hi Ed,,
Thanks for the reply.
Yes the I used the template created by Eclipse.It adds the org.eclipse.rap.ui in the dependencies page by default, and then its unable to resolve it.
Thanks and Regards,
Saurav
Re: Getting started with RAP [message #531013 is a reply to message #531008] Mon, 03 May 2010 07:49 Go to previous messageGo to next message
Saurav,
I wonder if there's a bug in the forum software that your reply removed
the RAP forum? Your reply appears only on the newcomers forum which, as
I suggested, is far less likely to solicit help from the RAP team then
using their specialized newsgroup.
You mentioned "I updated the tooling.It says it includes the runtime
also." I'm not sure what you did or what "It says it includes the
runtime" means, but you need to follow the instructions for installing
the runtime into a PDE target platform and making that target platform
the default/active one so that your workspace ends up resolve plugins
there. It sounds like you've not done that.
saurav wrote:
> Hi Ed,,
> Thanks and Regards,
> Saurav
Re: Getting started with RAP [message #531031 is a reply to message #531013] Mon, 03 May 2010 08:25 Go to previous messageGo to next message
Hi Saurav,
it is true that the RAP tooling contains the RAP runtime and a target
installer to ease getting started with RAP development. But if you are
using a mixed target (EMF + RAP + ...), you should rather get your
target components directly from a repository.
Here's a wiki page that explains how to use RAP + EMF:
http://wiki.eclipse.org/RAP/EMF_Integration
Feel free to post to the RAP newsgroup if you still have problems.
Regards, Ralf
Ed Merks wrote:
> Saurav,
> saurav wrote:
>> Hi Ed,,
>> Thanks and Regards,
>> Saurav
Re: Getting started with RAP [message #531054 is a reply to message #530957] Mon, 03 May 2010 10:23 Go to previous messageGo to next message
Thanks Ralf and Ed for the replies.
I tried using http://download.eclipse.org/rt/rap/1.3/runtime as the target definition.I am getting no software update site found.
I checked the network connection.It seems to be fine and I dont not use proxy here.
My question if at all i have the runtime bundled with IDE why i need to point it from an external location ?
I was using the RAP application creation template.Please find the code below.
<code>
package rapplugin;
import org.eclipse.rwt.lifecycle.IEntryPoint;
import org.eclipse.ui.PlatformUI;
import org.eclipse.ui.application.WorkbenchAdvisor;
* This class controls all aspects of the application's execution
* and is contributed through the plugin.xml.
public class Application implements IEntryPoint {
public int createUI() {
Display display = PlatformUI.createDisplay();
WorkbenchAdvisor advisor = new ApplicationWorkbenchAdvisor();
return PlatformUI.createAndRunWorkbench( display, advisor );
</code>
Where the IDE is not able to resolve IEntryPoint.
Its able to resolve other plug-ins like org.eclipse.rap.ui.intro and couple of other plug-ins but not the org.eclipse.rap.ui.
Best Regards,
Saurav
Re: Getting started with RAP [message #531062 is a reply to message #530957] Mon, 03 May 2010 10:45 Go to previous messageGo to next message
ok...What i did was i extracted the downloaded RAP runtime zip.Copied the plug-ins and features into my IDE's plug-ins.
Then put the RAP bundles in the Runtime configuration.This seems to work, though i got the following error
<code>
!ENTRY org.eclipse.rap.ui 4 0 2010-05-03 20:10:33.620
!MESSAGE Source Provider 'org.eclipse.ui.internal.contexts.ActiveContextSourceProvide r' should extend AbstractSourceProvider
java.lang.ClassCastException: org.eclipse.ui.internal.handlers.HandlerServiceFactory cannot be cast to org.eclipse.ui.services.AbstractServiceFactory
at org.eclipse.ui.internal.services.WorkbenchServiceRegistry.lo adFromRegistry(WorkbenchServiceRegistry.java:101)
at org.eclipse.ui.internal.services.WorkbenchServiceRegistry.ge tService(WorkbenchServiceRegistry.java:77)
at org.eclipse.ui.internal.services.ServiceLocator.getService(S erviceLocator.java:163)
at org.eclipse.ui.internal.Workbench$40.runWithException(Workbe nch.java:1642)
at org.eclipse.ui.internal.StartupThreading$StartupRunnable.run (StartupThreading.java:32)
at org.eclipse.rwt.internal.lifecycle.UICallBackManager.addSync (UICallBackManager.java:115)
at org.eclipse.swt.widgets.Display$2.run(Display.java:931)
at org.eclipse.rwt.internal.lifecycle.UICallBackServiceHandler. runNonUIThreadWithFakeContext(UICallBackServiceHandler.java: 460)
at org.eclipse.rwt.lifecycle.UICallBack.runNonUIThreadWithFakeC ontext(UICallBack.java:44)
at org.eclipse.swt.widgets.Display.syncExec(Display.java:929)
at org.eclipse.ui.internal.StartupThreading.runWithoutException s(StartupThreading.java:110)
at org.eclipse.ui.internal.Workbench.initializeDefaultServices( Workbench.java:1638)
at org.eclipse.ui.internal.Workbench.init(Workbench.java:1300)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2317)
at org.eclipse.ui.internal.Workbench.access$5(Workbench.java:22 06)
at org.eclipse.ui.internal.Workbench$4.run(Workbench.java:424)
at org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:332)
at org.eclipse.jface.internal.databinding.realmadapter.RealmAda pter.run(RealmAdapter.java:44)
at org.eclipse.rap.ui.internal.RealmAdapterHook.runWithDefault( RealmAdapterHook.java:48)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:427)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:157)
at rapplugin.Application.createUI(Application.java:18)
at org.eclipse.rwt.internal.lifecycle.EntryPointManager.createU I(EntryPointManager.java:92)
at org.eclipse.rwt.internal.lifecycle.RWTLifeCycle.createUI(RWT LifeCycle.java:253)
at org.eclipse.rwt.internal.lifecycle.RWTLifeCycle$UIThreadCont roller.run(RWTLifeCycle.java:117)
at org.eclipse.rwt.internal.lifecycle.UIThread.run(UIThread.jav a:80)
</code>
But my sample view is working.
cheers,
Saurav
Re: Getting started with RAP [message #531063 is a reply to message #531054] Mon, 03 May 2010 10:37 Go to previous messageGo to next message
Saurav,
I won't repeat the suggestion to use the RAP forum. Ralf might well not
see your question here.
> use proxy here.
> below.
> <code>
> package rapplugin;
> import org.eclipse.swt.widgets.Display;
> </code>
> Best Regards,
> Saurav
Re: Getting started with RAP [message #531078 is a reply to message #530957] Mon, 03 May 2010 12:14 Go to previous message
Hi Ed,
As per as your suggestion.
I am continuing the thread in the RAP forum here.
http://www.eclipse.org/forums/index.php?t=msg&goto=53107 7&#msg_531077
Saurav
Previous Topic:Opening Editor on a file
Next Topic:Eclipse does not clean build the web app with gwt
Current Time: Mon Sep 15 20:38:15 EDT 2025
Powered by FUDForum. Page generated in 0.08423 seconds
