Home » Modeling » Epsilon » Error message from ETL following Epsilon upgrade
Error message from ETL following Epsilon upgrade [message #530631] Fri, 30 April 2010 07:00 Go to next message
Originally posted by: c.k.holmes.lboro.ac.uk
I have recently upgraded to the latest stable release of Epsilon
(0.8.9.201004151115). Whilst running a transformation that worked
successfully under the previous interim release I noticed that the
following error (I assume its an error as it's shown in red) is now
being emitted in the console window:
[epsilon.etl - MyTx.etl] transformPriorityType
[epsilon.etl - MyTx.etl] pkg ->
org.eclipse.emf.ecore.impl.EPackageImpl@15a00b3 (name: <aSchemaName>)
(nsURI: mySchema.xsd, nsPrefix: aPrefix)
org.eclipse.emf.ecore.impl.EPackageImpl@11dadef (name: ParentPkg)
(nsURI: ParentNamespace, nsPrefix: Parent)
org.eclipse.emf.ecore.impl.EPackageImpl@1523d21 (name: ChildPkg) (nsURI:
ChildNamespace, nsPrefix: Child)
The message (which was not emitted in the previous release) appears to
relate to the following code in my ETL script:
operation Any transformPriorityType() {
'transformPriorityType'.println();
if (self = Source!PriorityType#NONE) {
return Target!ATargetTypeType#NONE;
} else if (self = Source!PriorityType#LOW) {
return Target!ATargetType#LOW;
} else if (self = Source!PriorityType#MEDIUM) {
return Target!ATargetType#MEDIUM;
} else if (self = Source!PriorityType#HIGH) {
return Target!ATargetType#HIGH;
} else {
throw 'transformPriorityType enumeration literal error. Unhandled
enumeration literal: ' + self.literal + '.';
This is invoked via the following Ant fragment:
<epsilon.etl src="${EtlFile}">
<model ref="${SourceName}" as="Source"/>
<model ref="${MessageSet}" as="Target"/>
<model ref="${DataDictionary}" as="DataDictionary"/>
</epsilon.etl>
Note that, whilst this appears to be indicated as an error, the
transformation runs to completion successfully and produces the expected
result.
Chris
Re: Error message from ETL following Epsilon upgrade [message #530651 is a reply to message #530631] Fri, 30 April 2010 08:23 Go to previous messageGo to next message
Hi Chris,
This is actually a debug message that was not cleared up and made it to
the stable version :( Please ignore these messages. I'll remove it and
release a new interim version shortly.
Dimitris
Chris Holmes wrote:
> } else {
> </epsilon.etl>
> result.
> Regards
> Chris
Spread the word: http://www.eclipse.org/gmt/epsilon/spreadtheword
Follow Epsilon on Twitter: http://twitter.com/epsilonews
Re: Error message from ETL following Epsilon upgrade [message #530652 is a reply to message #530651] Fri, 30 April 2010 08:38 Go to previous message
Hi Dimitris,
OK, cool ... just checking:)
Best Wishes
Chris
Dimitris Kolovos wrote:
> Hi Chris,
> Cheers,
> Dimitris
> Chris Holmes wrote:
>> Hi,
>> (nsURI: ChildNamespace, nsPrefix: Child)
>> } else {
>> </epsilon.etl>
>> expected result.
>> Regards
>> Chris
Re: Error message from ETL following Epsilon upgrade [message #588728 is a reply to message #530631] Fri, 30 April 2010 08:23 Go to previous message
Hi Chris,
Dimitris
Chris Holmes wrote:
> } else {
> </epsilon.etl>
> result.
> Regards
> Chris
Re: Error message from ETL following Epsilon upgrade [message #588739 is a reply to message #530651] Fri, 30 April 2010 08:38 Go to previous message
Hi Dimitris,
Best Wishes
Chris
> Hi Chris,
> Cheers,
> Dimitris
> Chris Holmes wrote:
>> Hi,
>> } else {
>> </epsilon.etl>
>> expected result.
>> Regards
>> Chris
Previous Topic:Error message from ETL following Epsilon upgrade
Next Topic:Where did my matches go?
Current Time: Sat Jul 26 21:35:20 EDT 2025
Powered by FUDForum. Page generated in 0.04769 seconds
