Home » Modeling » GMF (Graphical Modeling Framework) » Logic Diagram Example not working properly
Logic Diagram Example not working properly [message #530448] Thu, 29 April 2010 12:32 Go to next message
I have compiled the source code of Logic Diagram example after creating a project through the eclipse installed examples.
The problem is that when I try to draw Geometric shapes it works correctly but when I try to draw any logic shape such as Logic flow or circuit nothing happens.
Any help ?
Re: Logic Diagram Example not working properly [message #530459 is a reply to message #530448] Thu, 29 April 2010 13:18 Go to previous messageGo to next message
Did anyone try it and get it working ?
Re: Logic Diagram Example not working properly [message #530484 is a reply to message #530459] Thu, 29 April 2010 14:39 Go to previous messageGo to next message
I'm retrying again to build the example from CVS,
I had the following error
import org.eclipse.gmf.runtime.diagram.ui.editpolicies cannot be resolved.
Any hints on how to import the corresponding .jar file.
Re: Logic Diagram Example not working properly [message #530495 is a reply to message #530448] Thu, 29 April 2010 15:03 Go to previous messageGo to next message
Any help ?
Re: Logic Diagram Example not working properly [message #530496 is a reply to message #530448] Thu, 29 April 2010 15:07 Go to previous messageGo to next message
I tried rebuilding from CVS but I got the following error:
The import org.eclipse.gmf.runtime.diagram.ui.editpolicies.FlowLayoutEd itPolicy
cannot be resolve.
Any idea on where to get the jar file to resolve the error ?
Re: Logic Diagram Example not working properly [message #530517 is a reply to message #530496] Thu, 29 April 2010 18:14 Go to previous message
Again please,
did anyone in this forum try to run Logic Diagram example ?
Did you run successfully ?
If so, can you describe the steps ?
Thanks again for your help
Previous Topic:Problem with compartment
Next Topic:Having multiple icon for the same entity
Current Time: Sun Jul 20 22:49:33 EDT 2025
Powered by FUDForum. Page generated in 0.05174 seconds
