[MWE] Package with uri 'http://www.eclipse.org/uml2/3.0.0/UML' not found [message #489199] |
Thu, 01 October 2009 15:44  |
I want to generate code from an UML 2 model that uses a UML 2 profile.
In my mwe file I wrote:
<component class="org.eclipse.emf.mwe.utils.Reader">
<uri value="platform:/resource/${uwe_model_1}" />
<modelSlot value="model" />
</component>
I get this errors:
1-ott-2009 21.40.47 org.eclipse.emf.mwe.core.WorkflowRunner prepare
INFO: ------------------------------------------------------------ --------------------------
INFO: EMF Modeling Workflow Engine 0.7.2, Build v200908120417
INFO: (c) 2005-2009 openarchitectureware.org and contributors
INFO: running workflow: C:/Users/Federico/Documents/thesis/xpand_workspace/my.genera tor.projectSample/src/workflow/generator.mwe
INFO:
1-ott-2009 21.40.48 org.eclipse.emf.mwe.utils.StandaloneSetup setPlatformUri
INFO: Registering platform uri 'C:\Users\Federico\Documents\thesis\xpand_workspace'
1-ott-2009 21.40.48 org.eclipse.emf.mwe.core.container.CompositeComponent internalInvoke
INFO: Reader: Loading model from platform:/resource/UweProfile/uwe_example_1.uml
1-ott-2009 21.40.49 org.eclipse.emf.mwe.core.WorkflowRunner executeWorkflow
GRAVE: org.eclipse.emf.ecore.xmi.PackageNotFoundException: Package with uri 'http://www.eclipse.org/uml2/3.0.0/UML' not found. (platform:/resource/UweProfile/uwe_example_1.uml, 3, 70)
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl$1Diagnos ticWrappedException: org.eclipse.emf.ecore.xmi.PackageNotFoundException: Package with uri 'http://www.eclipse.org/uml2/3.0.0/UML' not found. (platform:/resource/UweProfile/uwe_example_1.uml, 3, 70)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.handleDe mandLoadException(ResourceSetImpl.java:315)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo adHelper(ResourceSetImpl.java:274)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResou rce(ResourceSetImpl.java:397)
at org.eclipse.emf.mwe.utils.Reader.load(Reader.java:54)
at org.eclipse.emf.mwe.utils.Reader.invokeInternal(Reader.java: 37)
at org.eclipse.emf.mwe.core.lib.AbstractWorkflowComponent.invok e(AbstractWorkflowComponent.java:124)
at org.eclipse.emf.mwe.core.container.CompositeComponent.intern alInvoke(CompositeComponent.java:101)
at org.eclipse.emf.mwe.core.container.CompositeComponent.invoke (CompositeComponent.java:86)
at org.eclipse.emf.mwe.core.WorkflowRunner.executeWorkflow(Work flowRunner.java:412)
at org.eclipse.emf.mwe.core.WorkflowRunner.run(WorkflowRunner.j ava:292)
at org.eclipse.emf.mwe.core.WorkflowRunner.main(WorkflowRunner. java:239)
Caused by: org.eclipse.emf.ecore.xmi.PackageNotFoundException: Package with uri 'http://www.eclipse.org/uml2/3.0.0/UML' not found. (platform:/resource/UweProfile/uwe_example_1.uml, 3, 70)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.getPackageForURI(X MLHandler.java:2590)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.getFactoryForPrefi x(XMLHandler.java:2421)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObjectByType (XMLHandler.java:1299)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.createTopObject(XM LHandler.java:1468)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.processElement(XML Handler.java:1019)
at org.eclipse.emf.ecore.xmi.impl.XMIHandler.processElement(XMI Handler.java:87)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHa ndler.java:1001)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHa ndler.java:712)
at org.eclipse.emf.ecore.xmi.impl.XMIHandler.startElement(XMIHa ndler.java:169)
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser .startElement(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl.scanStartElement(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl$FragmentContentDriver.next(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerIm pl.next(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl.scanDocument(Unknown Source)
at com.sun.org.apache.xerces.internal.parsers.XML11Configuratio n.parse(Unknown Source)
at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(U nknown Source)
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser .parse(Unknown Source)
at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSA XParser.parse(Unknown Source)
at javax.xml.parsers.SAXParser.parse(Unknown Source)
at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl. java:181)
at org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doLoad(XMLRes ourceImpl.java:180)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:1494)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:1282)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo ad(ResourceSetImpl.java:255)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo adHelper(ResourceSetImpl.java:270)
... 9 more
How can I correct it?
I believed that I could just insert something like:
<uri value=" jar:file:/D:/eclipse-jee-galileo-win32/eclipse/plugins/org.e clipse.uml2.uml.resources_3.0.0.v200906011111.jar!/profiles/ UML2.profile.uml " />
but I was wrong...
Thank you,
Federico
Re: [MWE] Package with uri 'http://www.eclipse.org/uml2/3.0.0/UML' not found [message #489399 is a reply to message #489199] |
Fri, 02 October 2009 15:15   |
Hi Frederico,
you'll have to register the uml metamodel in the standalone setup of
your workflow:
<bean class="org.eclipse.emf.mwe.utils.StandaloneSetup">
<registerGeneratedEPackage value="fully.qualified.name.of.EPackage"/>
</bean>
Hope that helps,
Sebastian
> </component>
> I get this errors:
> INFO: 1-ott-2009 21.40.48 org.eclipse.emf.mwe.utils.StandaloneSetup
> setPlatformUri
> 1-ott-2009 21.40.48
> ava:292)
> java:239)
> LHandler.java:1468)
> Handler.java:1019)
> Handler.java:87)
> ndler.java:1001)
> ndler.java:712)
> ndler.java:169)
> nknown Source)
> java:181)
> ourceImpl.java:180)
> ceImpl.java:1494)
> ceImpl.java:1282)
> ... 9 more
> <uri value="
> but I was wrong...
> Thank you,
> Federico
Re: [MWE] Package with uri 'http://www.eclipse.org/uml2/3.0.0/UML' not found [message #530430 is a reply to message #530155] |
Thu, 29 April 2010 11:16  |
Hi Daniel,
if you use static EMF, there is will be several classes available that
reflect the structure of your metamodel. One of them is the EPackage
which is usually called <Name>Package where <Name> denotes the name of
your ePackage as visible in the properties view of your ecore editor.
If there are no static classes available, you'll have to register the
ecore file itself as dynamic resource.
<registerEcoreFile value="<uri to ecore file>"/>
</bean>
Hope that helps,
Sebastian
Am 28.04.10 18:46, schrieb Daniel Ruiz:
> What does "fully.qualified.name.of.EPackage" mean?
> I tried "org.eclipse.uml2.uml.UMLPackage" but it couldn't find it.
> Thank you!
> El 02/10/2009 21:15, Sebastian Zarnekow escribió:
>> Hi Frederico,
>> your workflow:
>> </bean>
>> Hope that helps,
>> Sebastian
FUDForum. Page generated in 0.05893 seconds
