I need AM3 plugin compatible with Galilo modeling Eclipse, [message #529986] |
Tue, 27 April 2010 18:46  |
Hi all
I need to run an ANT file and it requires the AM3 as following
Quote: |
<project name="UML2OWL" default="transfo">
<!-- Change this value if you want to use another input model -->
<property name="model" value="Museum"/>
<target name="transfo" depends="loadModels">
<am3.loadModel name="umlModel" metamodel="UML" path="/UML2OWL/Samples/UMLModels/${model}.uml"/>
<am3.atl path="/UML2OWL/UML2OWL.asm">
<inModel name="IN" model="umlModel"/>
<inModel name="UML" model="UML"/>
<inModel name="OWL" model="OWL"/>
<outModel name="OUT" model="owlModel" metamodel="OWL"/>
</am3.atl>
<am3.saveModel model="owlModel" path="/UML2OWL/Samples/OWLModels/${model}-OWL.ecore"/>
<am3.atl path="/UML2OWL/OWL/XmlSyntax/OWL2XML.asm">
<inModel name="IN" model="owlModel"/>
<inModel name="XML" model="XML"/>
<outModel name="OUT" model="xmlModel" metamodel="XML"/>
</am3.atl>
<am3.saveModel model="xmlModel" path="/UML2OWL/Samples/OWLFiles/${model}.owl">
<extractor name="xml"/>
</am3.saveModel>
</target>
<target name="loadModels">
<!-- Load UML 2.0 metamodel-->
<am3.loadModel modelHandler="EMF" name="UML" metamodel="MOF" nsuri="http://www.eclipse.org/uml2/2.0.0/UML"/>
<!-- Load OWL metamodel-->
<am3.loadModel modelHandler="EMF" name="OWL" metamodel="MOF" path="/UML2OWL/OWL/OWL.ecore"/>
<!-- Load XML metamodel-->
<am3.loadModel modelHandler="EMF" name="XML" metamodel="MOF" path="/UML2OWL/AMMACore/XML.ecore"/>
</target>
</project>
It is the example of UML2OWl, how can i run the ant file and if I need the AM3 as mentioned how could I get it as a compatible with my eclipse Galileo Version
please I need it very soon
thanks for who read and HELP
wafaa
[Updated on: Tue, 27 April 2010 18:47] by Moderator
Re: I need AM3 plugin compatible with Galilo modeling Eclipse, [message #530125 is a reply to message #530025] |
Wed, 28 April 2010 10:58  |
Guillaume Doux wrote on Wed, 28 April 2010 04:31 | Hello Wafaa,
The ANT task you use are now deprecated and will not work with Eclipse galileo and ATL 3.0. These ANT tasks work until ATL 2.
You should now use the new ANT task that have been designed for ATL 3. You can look at the online documentation ( http://wiki.eclipse.org/ATL/User_Guide_-_The_ATL_Tools#ATL_a nt_tasks).
Hope it helps.
Guillaume Doux
Thank you very much Guillaume for ur reply, but what is the new version where i can find it? and if it was via CVS please direct me to the steps of downloading it and insalling them, about the tutorial I read it actually i do not want to write one, i want to run it so should I have the Apache( for example) installed on my PC,
Repeating my thanks
[Updated on: Wed, 28 April 2010 10:59] by Moderator
FUDForum. Page generated in 0.06798 seconds
