Home » Eclipse Projects » Eclipse Platform » extreme slow "refreshing external folders"
extreme slow "refreshing external folders" [message #529774] Tue, 27 April 2010 03:54 Go to next message
we're using RAD75, IBM's IDE build upon Eclipse 3.4.2
Ever since we moved to this version, several of our developers have reported excruciating slow refreshing issues. For who knows what reason, the IDE starts "refreshing external folders" and just hangs for about 10 to 15 minutes!
The source-code loaded into the workspace is imported from a directory that is under version control, and is not located within the workspace.
Does anybody have similar experience, or better, a solution?
maybe some settings...?
Re: extreme slow "refreshing external folders" [message #529933 is a reply to message #529774] Tue, 27 April 2010 14:03 Go to previous messageGo to next message
Mark,
It sounds like a network delay issue. Do they have the workspace auto
refresh preference enabled?
It seems to me that a proper version control system would involve
extracting a local copy from the version control system, rather than
sharing a folder across developers...
Re: extreme slow "refreshing external folders" [message #531331 is a reply to message #529933] Tue, 04 May 2010 10:45 Go to previous messageGo to next message
The auto-refresh is (mostly) "on"
We are using "snapshots", local copies of the source-code.
The developer manually triggers the update of this snapshot to update his copy with the newly checked in code from the others.
The location of this snapshot is in a specific directory on the developer's pc, but not within the RAD workspace-directory, hence the "external folders"
The thing is that RAD randomly (?) decides to update his internal index and on some pc's this process hangs RAD...
Rather weird taking into account that the "auto-refresh" and the "refresh workspace on startup" already should have captured all changes made by the user...
Re: extreme slow "refreshing external folders" [message #531376 is a reply to message #531331] Tue, 04 May 2010 11:38 Go to previous message
Mark,
If it's an external file system there might be issues with clock
synchronization that make the files look out of date with respect to the
expected timestamp on the local machine. It sounds a little like that.
You might want to try disabling auto refresh and see if that helps.
> "external folders"
Previous Topic:Toggling selection effect to the list component
Next Topic:How to Setup Client Dev Environment for FileNet P8 4.x with JBoss and Eclipse
Current Time: Sun Jul 27 14:00:51 EDT 2025
Powered by FUDForum. Page generated in 0.28144 seconds
