Jira-Connector, Mylyn 3.3.3: Attaching task context with Umlaute comment doens't work [message #529888] |
Tue, 27 April 2010 11:09  |
My setup:
- Mylyn 3.3.3
- Jira-Connector
When I want to attach a task context with a comment, which is including some Umlaute chars then somehow the Jira connector doesn't handle this Umlaute correctly. The Umlaute chars appears then as "?"(question marks) and not for example "ä, ö, ü, etc.".
When I add normal comments through the rich-text editor for the task, the Umlaute are handled correctly. The problem is only with the appearing dialog when you attach a task context to the task and if you enter in this dialog a comment with Umlaute chars.
Do I have to set a special encoding configuration for this or is this maybe a bug?
Thanks for help!
FUDForum. Page generated in 0.07422 seconds
