Home » Modeling » M2T (model-to-text transformation) » [Acceleo] Cast between two metamodels (How to cast an object from a metamodel class to an other one )
[Acceleo] Cast between two metamodels [message #529628] Mon, 26 April 2010 11:11 Go to next message
Hi everyone
I'm trying to generate code from two metamodels, MA and MB.
The problem I'm facing is the following:
I have a class B in MB, which inherits from class A in MA.
I'd like to access some attributes in B, while I'm browsing classes A and B, like a basic Cast in java
Unfortunately, oclAsType() method works fine while I'm using classes from the same Metamodel, not if I want to use it with A and B like :
a.oclAsType(B), I get "Unrecognized variable: (B)" in
[template public write(a : A)]
    [for (n : Node | a.children)]
        [if (n.oclIsKindOf(Attribute))]
             [n.oclAsType(B).write()/]
        [/if]
     [/for]
[/template]
Is there another way I'm not aware of to do this? maybe not using OCL ?
Nicolas
Re: [Acceleo] Cast between two metamodels [message #529782 is a reply to message #529628] Tue, 27 April 2010 04:24 Go to previous messageGo to next message
--------------040204020007060002080507
Hi Nicolas,
I believe OCL is just confused between your metamodels. Would
"a.oclAsType(MB::B)" do the trick?
(I recently made some tweaks in Acceleo so that the use of qualified
names for types will be useless in most cases ... but these changes
haven't been built yet)
Laurent Goubet
Obeo
Nicolas Guyomar wrote:
> Hi everyone
> [/if] [/for]
> [/template]
> Regards
> Nicolas
name="laurent_goubet.vcf"
filename="laurent_goubet.vcf"
bjoyLjENCmVuZDp2Y2FyZA0KDQo=
--------------040204020007060002080507--
[Solved] [Acceleo] Cast between two metamodels [message #529799 is a reply to message #529782] Tue, 27 April 2010 05:29 Go to previous messageGo to next message
Hi Laurent,
Thank you for your quick answer
The solution you proposed works perfectly, I assume this syntax is pretty common in OCL .. shame on me
Thank you again
Nicolas
Re: [Solved] [Acceleo] Cast between two metamodels [message #529832 is a reply to message #529799] Tue, 27 April 2010 08:03 Go to previous message
--------------040806090006080500040407
Nicolas,
It is a common syntax in OCL ... but I doubt many people know all of the
different things we can do with OCL :p.
Laurent Goubet
Obeo
> Hi Laurent,
> Thank you again
> Nicolas
--------------040806090006080500040407--
Previous Topic:[Xpand] Write an example conforming to model ?
Next Topic:[MWE] Package with uri 'http://www.eclipse.org/uml2/3.0.0/UML' not found
Current Time: Wed Jul 30 21:27:10 EDT 2025
Powered by FUDForum. Page generated in 0.06903 seconds
