Home » Archived » Test and Performance Tools Platform (TPTP) » Re: Agent Controller and Java 1.5/5.0
Re: Agent Controller and Java 1.5/5.0 [message #52854] Sat, 04 February 2006 23:02 Go to next message
Originally posted by: jkp1974a.cox.net
Hello.
I was looking at the Agent Controller configuration page for Windows -
http://www.eclipse.org/tptp/home/downloads/installguide/Agen tController41.html
and noticed that the requirement for JDK/JRE is 1.4. Does that mean Java
1.5/5.0 does not work w/ profiling?
Thanks in advance.
Ken
Re: Agent Controller and Java 1.5/5.0 [message #52908 is a reply to message #52854] Mon, 06 February 2006 10:26 Go to previous messageGo to next message
Originally posted by: nmehrega.ca.ibm.com
Although TPTP doesn't officially support JDK 1.5, I've personally tested
the profiler with JDK 1.5 and didn't find any problems. Now the test
cases obviously don't cover every single use case, but I don't really
suspect you'll find any problems using the profiler with JDK 1.5.
Navid Mehregani
Re: Agent Controller and Java 1.5/5.0 [message #52934 is a reply to message #52854] Mon, 06 February 2006 11:53 Go to previous messageGo to next message
In my experience TPTP does not work at all with JDK 1.5/Java5. Please
have a look at the following bug report:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=125643
Andreas
Re: Agent Controller and Java 1.5/5.0 [message #52959 is a reply to message #52934] Mon, 06 February 2006 12:25 Go to previous messageGo to next message
Hello all ->
Thanks for your replials.
Ideally, I would like to be able to profile with the following 1.5/5.0
constructs/features:
1. Collections (Sort, etc...)
2. ArrayList/HashMap (with type parameters)
[3. for/in loop]
I am trying to profile web services. Thus, my current setup:
Windows XP SP2
Java 1.5.0_06 (5.0)
WTP 1.0 (all-in-one)
I was going to try to use TPTP 4.1; should I try the TPTP 4.2M4 release
(per Andreas's link)?
Thanks again for everyone's responses so far. If I figure something out
(or an answer to the conflicting info), I'll try to post.
Ken
Re: Agent Controller and Java 1.5/5.0 [message #52984 is a reply to message #52908] Mon, 06 February 2006 13:19 Go to previous messageGo to next message
> Navid Mehregani
Is there a good link/docs on the Profiler? I was looking the other day
and came up pretty much empty handed.
Re: Agent Controller and Java 1.5/5.0 [message #53137 is a reply to message #52984] Tue, 07 February 2006 10:40 Go to previous messageGo to next message
Mark,
On the TPTP website, click on Documents -> under User Guides &
Demonstrations, there is a document called "An Introduction in Profiling
Java Applications (v3.2.0)" and there is also a video called: "Demo:
Profiling an application".
Navid Mehregani
Re: Agent Controller and Java 1.5/5.0 [message #53162 is a reply to message #53137] Tue, 07 February 2006 11:29 Go to previous message
> Mark,
> Navid Mehregani
Thanks a million. I was in the wrong place.
Previous Topic:Problems with UML2 diagrams
Next Topic:Dynamic Web Projects (WTP) and TPTP
Current Time: Mon Nov 03 01:33:12 EST 2025
Powered by FUDForum. Page generated in 0.04777 seconds
