Home » Eclipse Projects » Eclipse Platform » Logfile of console log, e. g. for build run
Logfile of console log, e. g. for build run [message #529412] Sat, 24 April 2010 16:34 Go to next message
is the output of the console, e. g. from an Ant build run, also logged in a
file - if yes, where?
Thomas Wiedmann
Re: Logfile of console log, e. g. for build run [message #529414 is a reply to message #529412] Sat, 24 April 2010 17:32 Go to previous message
Hi Thomas-san,
If I got your point correctly, can you check below:
Go to Run / Debug Settings
-> Go to 'Common' tab
-> Select 'File' checkbox in 'Standard Input and Output' group and specify output file name, which is not selected by default.
Hope this works
Thanks regards,
Mitsuki
Previous Topic:Missing META-INF folder in build result (eclipse SDK)
Next Topic:Error when starting Eclipse
Current Time: Wed Jul 23 04:06:52 EDT 2025
Powered by FUDForum. Page generated in 0.08428 seconds
