Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Zoom view to a specific size or % of screen(Zoom view to a specific size or % of screen)
Zoom view to a specific size or % of screen [message #529190] Fri, 23 April 2010 07:12 Go to next message
I would like to be able to do the following.
I have a page layout with folders split into three areas.
Two views displayed side by side , which take 90% of the page hieght and 50% of the page width. ( Views A and B )
One view along the bottom with takes 10% of the page height and 100% of the page width. ( view C ).
I would like to programatically zoom/maximize view A so that
it fills 90% of the height and 100% of the width ( so it hides view B but does not hide view C ).
Can somebody point me in the right direction.
I can use IWorkbenchPage.toggleZoom() to maximise view A, but I dont know if there is something I can do with the
pageLayout to achieve what I wanr.
Thanks.
[Updated on: Fri, 23 April 2010 07:14] by Moderator
Re: Zoom view to a specific size or % of screen [message #529239 is a reply to message #529190] Fri, 23 April 2010 10:36 Go to previous message
I've redirected to RCP since this is not an SWT problem.
Richard Hughes wrote:
> Hi
> I have a page layout width folders split into three areas.
> I would like to programitcally zoom/maximize view A so that
> it fills 90% of the height and 100% of the width ( so does not
> hide view C ).
> know if there is something I can do with the pageLayout
> Thanks.
There's no API to do what you want. It sounds like you want to reset
the weights on the part sash containers. I'm not even sure how you
would get that except by wading through the presentation/layout code.
That's all internals, and can change at any time (and it pretty scary, too).
If you do want to try and make it work for your specific version of
eclipse, you can have a read of
http://www.eclipse.org/articles/Article-UI-Workbench/workben ch.html
Later,
PW
Paul Webster
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/guide/workbench.htm
Previous Topic:Add menu option to popup on View tab
Next Topic:How do I open office documents using SWT
Current Time: Fri Jul 25 20:35:01 EDT 2025
Powered by FUDForum. Page generated in 0.04577 seconds
