Postscript page count [message #528803] |
Wed, 21 April 2010 15:53  |
I'm trying to get BIRT to display a page count (Page n of m) when printing on a server. Right now I'm making a http request to the server, which processes the report and sends postscript print jobs just fine. There is a bug that is keeping the total page count from showing when I do this:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=180416
I noticed in the bug comments there's may be some kind of workaround:
"... those issues only exist in runAndRender task. The result of
run then render is correct."
Is there some way I can get this to happen, or is there no way around this without a bug fix?
Re: Postscript page count [message #529271 is a reply to message #529269] |
Fri, 23 April 2010 12:25   |
If it does not can you post the report?
On 4/23/2010 12:23 PM, Jason Weathersby wrote:
> Paul,
> If you use the viewer with frameset and specify html output does it work?
> Jason
> On 4/23/2010 10:39 AM, Paul wrote:
>> I'm not having any luck getting the page count to show using a basic
>> test through the browser using that method (Typically this call would be
>> made by a java app). Through my browser, I've tried a couple of
>> variations using the __document parameter while changing up format
>> (tried pdf, postcript, and removing the param) and testing with and
>> without the __printer and __action parameters. It creates the document
>> (the browser actually returns it), then I run the second query (that is
>> the query without the __report parameter, that also contains the
>> __action=print) and it prints the document. The problem is it still
>> doesn't print the total page count. Also when it returns a postscript,
>> it returns without the page count. :?
Re: Postscript page count [message #636491 is a reply to message #636461] |
Mon, 01 November 2010 10:58  |
Try selecting the Birt Perspective and clicking on
run->View Report->In Web Viewer.
Jason
On 11/1/2010 9:09 AM, R.Murali wrote:
> Hi
> am new to BIRT
> How to run report in client eclipse...
> am using eclipse 3.6 and BIRT 2.6.....
> i can able to design a report and view the report by clicking Preview
> tab....
> What i want to do is,i want to run the report output in separate Window....
> Can anybody help me
FUDForum. Page generated in 0.07244 seconds
