setSelection in TableViewer unable to select row from non-UI thread. [message #528826] |
Wed, 21 April 2010 19:48  |
I have trying to select/highlight a row in JFace TableViewer from a non-ui thread using setSelection method. Somehow i am not able to get it working. I am using setSelection method. Somehow my viewer gets completely messed up. I am able to see all the rows above the "selected" row. I dont see anything below the "selected" row and only 1st column of the selected row is visible.
I want to retain "selection" of a row after some updates have taken place. TableViewer is VIRTUAL.
Not sure what i am doing wrong. Any suggestions/pointers will be a great help.
Here is a snippet, i can provide more details.
private void subscribeToJMS()
Runnable r = new Runnable () {
public void run() {
display.syncExec (new Runnable () {
public void run () {
if( display != null && !display.isDisposed() )
updateViewer();
public synchronized void updateViewer()
int index = model.indexOf(ot);
if(index != -1) {
model.remove(ot);
if (brrOrder.getTopicName().equals(IBrrConstants.ETS_BRR_FOR_LO CK) ||
brrOrder.getTopicName().equals(IBrrConstants.ETS_BRR_FOR_UNL OCK)){
model.add(index, ot);
grid.updateModel(model, false, true); // does a tableViewer.refresh
// sets the selection back.
StructuredSelection sel = new StructuredSelection(tableViewer.getElementAt(index));
tableViewer.setSelection(sel, true);
Thanx
Priyanka
[Updated on: Wed, 21 April 2010 19:57] by Moderator
Re: setSelection in TableViewer unable to select row from non-UI thread. [message #528841 is a reply to message #528826] |
Thu, 22 April 2010 02:16   |
On 22.04.2010 01:48, PM wrote:
> the selected row is visible. I want to retain "selection" of a row after
> help.
> public void run() {
> updateViewer();
It does not make much sense to combine syncExec with a query for
display != null && !display.isDisposed(). To prevent a potential
deadlock problem, use asyncExec *with* above test.
> if(index != -1) {
> model.remove(ot);
This looks more like a jface problem (based on TableViewer
API) than a pure SWT problem. Some hints:
1) Don't use TableViewer.getElementAt, this is no official
API ("This method is internal to the framework").
2) You don't inform the Table(Viewer) about your changes
(I do only see that you change your model). Based on jface
API you should call Viewer.refresh();
There could still be problems with your code, but that
is hard to diagnose without a concrete simple program
snippet that demonstrate the unexpected behaviour.
HTH & Greetings from Bremen,
Daniel Krügler
Re: setSelection in TableViewer unable to select row from non-UI thread. [message #528844 is a reply to message #528841] |
Thu, 22 April 2010 02:24   |
Am 22.04.10 08:16, schrieb Daniel Krügler:
>> Hi,
>> help.
>> public void run() {
>> updateViewer();
>> if(index != -1) {
>> model.remove(ot);
What is grid.updateModel() doing? Where is ot coming from? Why are you
not calling new StructuredSelection(ot)? It looks like there's a check
missing which tests for -1 (the remove case)?
or Viewer#remove/add.
Tom
Re: setSelection in TableViewer unable to select row from non-UI thread. [message #529061 is a reply to message #528844] |
Thu, 22 April 2010 15:12  |
Thanx very much Daniel & Tom. I was able to solve my problem using your inputs.
I did 3 things that seemed to work.
1. Swapped syncExec with asyncExec.
2. Performed tableViewer.refresh() after underlying model is updated.
3. Replaced StructuredSelection sel = new StructuredSelection(tableViewer.getElementAt(index) by StructuredSelection sel = new StructuredSelection(ot);
List<ITopsModelObject> model = grid.getModel();
// check for updates
// If the OrderTicket is already in the model, remove and then add.
for (Iterator<ITopsModelObject> it = newList.iterator(); it.hasNext();){
ITopsModelObject ot = it.next();
// should use overridden equals and hashCode method.
if(index != -1) {
model.remove(ot);
tableViewer.refresh();
Thanx once again for your time and your prompt replies.
FUDForum. Page generated in 0.03368 seconds
