Home » Archived » BPMN Modeler » generating bpmn_diagram from bpmn file or why did the semantic refresh fail?
generating bpmn_diagram from bpmn file or why did the semantic refresh fail? [message #528599] Wed, 21 April 2010 04:47 Go to next message
Hello newsgroup,
I just installed the BPMN modeler. I programmatically made some
modifications (moved some tasks to a subprocess) to the underlying model
(the bpmn file) of a bpmn diagram. As I saw that I didn't get asked if
to reload the diagram because of some changes being made, I closed the
diagram file and re-opened it. But then I got some NPE's in the error
log and a strange diagram. Besides that I got the following error in the
log with the stacktrace below:
IRJS0007E Semantic refresh failed.
When I wnated to drag and drop elements on the canvas I got more NPE's.
Then I created a new model mirroring the same model which I expected
after my programmatically made modifications. Then I deleted the diagram
file and tried to invoke "initialize bpmn_diagram file" on the bpmn file
(normal behavior for GMF editors). The diagram was generated but when
opening it I got exactly the same errors as above. So I'm asking why is
that not supported or if I find a fix in the repository version?
best regards,
Jan
at
org.eclipse.gmf.runtime.diagram.ui.editparts.GraphicalEditPa rt.setVisibility(GraphicalEditPart.java:1034)
at
org.eclipse.gmf.runtime.diagram.ui.editparts.GraphicalEditPa rt.refreshVisibility(GraphicalEditPart.java:920)
at
org.eclipse.gmf.runtime.diagram.ui.editparts.GraphicalEditPa rt.refreshVisuals(GraphicalEditPart.java:926)
at
org.eclipse.stp.bpmn.diagram.edit.parts.ActivityNameEditPart .refreshVisuals(ActivityNameEditPart.java:465)
at
org.eclipse.stp.bpmn.diagram.edit.parts.ActivityNameEditPart .setLabel(ActivityNameEditPart.java:220)
at
org.eclipse.stp.bpmn.diagram.edit.parts.ActivityEditPart.add FixedChild(ActivityEditPart.java:342)
at
org.eclipse.stp.bpmn.diagram.edit.parts.ActivityEditPart.add ChildVisual(ActivityEditPart.java:549)
at
org.eclipse.gef.editparts.AbstractEditPart.addChild(Abstract EditPart.java:197)
at
org.eclipse.gmf.runtime.diagram.ui.editparts.GraphicalEditPa rt.addChild(GraphicalEditPart.java:1319)
at
org.eclipse.gef.editparts.AbstractEditPart.refreshChildren(A bstractEditPart.java:727)
at
org.eclipse.gef.editparts.AbstractEditPart.refresh(AbstractE ditPart.java:677)
at
org.eclipse.gef.editparts.AbstractGraphicalEditPart.refresh( AbstractGraphicalEditPart.java:571)
at
org.eclipse.gmf.runtime.diagram.ui.editparts.GraphicalEditPa rt.access$3(GraphicalEditPart.java:1)
at
org.eclipse.gmf.runtime.diagram.ui.editparts.GraphicalEditPa rt$3.run(GraphicalEditPart.java:861)
at
org.eclipse.emf.transaction.impl.TransactionalEditingDomainI mpl.runExclusive(TransactionalEditingDomainImpl.java:313)
at
org.eclipse.gmf.runtime.diagram.ui.editparts.GraphicalEditPa rt.refresh(GraphicalEditPart.java:851)
at
org.eclipse.gef.editparts.AbstractEditPart.addNotify(Abstrac tEditPart.java:235)
at
org.eclipse.gef.editparts.AbstractGraphicalEditPart.addNotif y(AbstractGraphicalEditPart.java:219)
at
org.eclipse.gef.editparts.AbstractEditPart.addChild(Abstract EditPart.java:198)
at
at
at
at
at
at
at
at
at
org.eclipse.gmf.runtime.diagram.ui.editpolicies.CanonicalEdi tPolicy.postProcessRefreshSemantic(CanonicalEditPolicy.java: 1205)
at
org.eclipse.gmf.runtime.diagram.ui.editpolicies.CanonicalEdi tPolicy.refreshSemanticChildren(CanonicalEditPolicy.java:113 9)
at
org.eclipse.gmf.runtime.diagram.ui.editpolicies.CanonicalEdi tPolicy.refreshSemantic(CanonicalEditPolicy.java:997)
at
org.eclipse.gmf.runtime.diagram.ui.editpolicies.CanonicalEdi tPolicy.refresh(CanonicalEditPolicy.java:979)
at
org.eclipse.gmf.runtime.diagram.ui.editpolicies.CanonicalEdi tPolicy.refreshOnActivate(CanonicalEditPolicy.java:656)
at
org.eclipse.gmf.runtime.diagram.ui.editpolicies.CanonicalEdi tPolicy.activate(CanonicalEditPolicy.java:646)
at
org.eclipse.gef.editparts.AbstractEditPart.activateEditPolic ies(AbstractEditPart.java:165)
at
org.eclipse.gef.editparts.AbstractEditPart.activate(Abstract EditPart.java:148)
at
org.eclipse.gef.editparts.AbstractGraphicalEditPart.activate (AbstractGraphicalEditPart.java:193)
at
org.eclipse.gmf.runtime.diagram.ui.editparts.GraphicalEditPa rt.access$0(GraphicalEditPart.java:1)
at
org.eclipse.gmf.runtime.diagram.ui.editparts.GraphicalEditPa rt.activate(GraphicalEditPart.java:205)
at
org.eclipse.gef.editparts.AbstractEditPart.activate(Abstract EditPart.java:152)
at
at
at
at
org.eclipse.gef.editparts.AbstractEditPart.addChild(Abstract EditPart.java:201)
at
at
at
org.eclipse.gmf.runtime.diagram.ui.editparts.GraphicalEditPa rt.handleNotificationEvent(GraphicalEditPart.java:1464)
at
org.eclipse.stp.bpmn.diagram.edit.parts.BpmnDiagramEditPart. handleNotificationEvent(BpmnDiagramEditPart.java:249)
at
org.eclipse.gmf.runtime.diagram.ui.editparts.GraphicalEditPa rt.notifyChanged(GraphicalEditPart.java:1438)
at
org.eclipse.gmf.runtime.diagram.core.listener.DiagramEventBr oker.fireNotification(DiagramEventBroker.java:500)
at
org.eclipse.gmf.runtime.diagram.core.listener.DiagramEventBr oker.resourceSetChanged(DiagramEventBroker.java:395)
at
org.eclipse.gmf.runtime.diagram.ui.DiagramEventBrokerThreadS afe.resourceSetChanged(DiagramEventBrokerThreadSafe.java:73)
at
org.eclipse.gmf.runtime.diagram.core.DiagramEditingDomainFac tory$DiagramEditingDomain.postcommit(DiagramEditingDomainFac tory.java:213)
at
org.eclipse.emf.transaction.impl.TransactionalEditingDomainI mpl.deactivate(TransactionalEditingDomainImpl.java:528)
at
org.eclipse.emf.transaction.impl.TransactionImpl.close(Trans actionImpl.java:712)
at
org.eclipse.emf.transaction.impl.TransactionImpl.commit(Tran sactionImpl.java:474)
at
org.eclipse.emf.workspace.AbstractEMFOperation.execute(Abstr actEMFOperation.java:155)
at
org.eclipse.gmf.runtime.diagram.ui.editpolicies.CanonicalEdi tPolicy.executeCommand(CanonicalEditPolicy.java:510)
at
org.eclipse.gmf.runtime.diagram.ui.editpolicies.CanonicalEdi tPolicy.createViews(CanonicalEditPolicy.java:466)
at
org.eclipse.gmf.runtime.diagram.ui.editpolicies.CanonicalEdi tPolicy.refreshSemanticChildren(CanonicalEditPolicy.java:111 6)
at
org.eclipse.stp.bpmn.diagram.edit.policies.BpmnDiagramCanoni calEditPolicy.refreshSemantic(BpmnDiagramCanonicalEditPolicy .java:159)
at
at
org.eclipse.gmf.runtime.diagram.ui.editpolicies.CanonicalCon nectionEditPolicy.refreshOnActivate(CanonicalConnectionEditP olicy.java:108)
at
at
at
at
at
at
at
org.eclipse.gmf.runtime.diagram.ui.editparts.DiagramEditPart .activate(DiagramEditPart.java:349)
at
at
org.eclipse.gef.editparts.SimpleRootEditPart.setContents(Sim pleRootEditPart.java:101)
at
org.eclipse.gef.ui.parts.AbstractEditPartViewer.setContents( AbstractEditPartViewer.java:601)
at
org.eclipse.gmf.runtime.diagram.ui.parts.DiagramGraphicalVie wer.setContents(DiagramGraphicalViewer.java:378)
at
org.eclipse.gef.ui.parts.AbstractEditPartViewer.setContents( AbstractEditPartViewer.java:610)
at
org.eclipse.gmf.runtime.diagram.ui.parts.DiagramEditor.initi alizeGraphicalViewerContents(DiagramEditor.java:870)
at
org.eclipse.gmf.runtime.diagram.ui.parts.DiagramEditor.initi alizeGraphicalViewer(DiagramEditor.java:863)
at
org.eclipse.gmf.runtime.diagram.ui.parts.DiagramEditorWithFl yOutPalette.initializeGraphicalViewer(DiagramEditorWithFlyOu tPalette.java:116)
at
org.eclipse.gmf.runtime.diagram.ui.resources.editor.parts.Di agramDocumentEditor.initializeGraphicalViewer(DiagramDocumen tEditor.java:175)
at
org.eclipse.gmf.runtime.diagram.ui.parts.DiagramEditor.creat eGraphicalViewer(DiagramEditor.java:807)
at
org.eclipse.gef.ui.parts.GraphicalEditor.createPartControl(G raphicalEditor.java:163)
at
org.eclipse.gmf.runtime.diagram.ui.parts.DiagramEditor.creat ePartControl(DiagramEditor.java:1555)
at
org.eclipse.gmf.runtime.diagram.ui.parts.DiagramEditorWithFl yOutPalette.createPartControl(DiagramEditorWithFlyOutPalette .java:328)
at
org.eclipse.gmf.runtime.diagram.ui.resources.editor.parts.Di agramDocumentEditor.createPartControl(DiagramDocumentEditor. java:1510)
at
org.eclipse.ui.internal.EditorReference.createPartHelper(Edi torReference.java:662)
at
org.eclipse.ui.internal.EditorReference.createPart(EditorRef erence.java:462)
at
org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:595)
at
org.eclipse.ui.internal.EditorReference.getEditor(EditorRefe rence.java:286)
at
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched( WorkbenchPage.java:2857)
at
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(Workben chPage.java:2762)
at org.eclipse.ui.internal.WorkbenchPage.access$11(WorkbenchPag e.java:2754)
at org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.j ava:2705)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:70)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2701)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2685)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2676)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:651)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:610)
at
org.eclipse.jdt.internal.ui.javaeditor.EditorUtility.openInE ditor(EditorUtility.java:361)
at
org.eclipse.jdt.internal.ui.javaeditor.EditorUtility.openInE ditor(EditorUtility.java:168)
at org.eclipse.jdt.ui.actions.OpenAction.run(OpenAction.java:22 9)
at org.eclipse.jdt.ui.actions.OpenAction.run(OpenAction.java:20 8)
at
org.eclipse.jdt.ui.actions.SelectionDispatchAction.dispatchR un(SelectionDispatchAction.java:274)
at
org.eclipse.jdt.ui.actions.SelectionDispatchAction.run(Selec tionDispatchAction.java:250)
at
org.eclipse.jdt.internal.ui.packageview.PackageExplorerActio nGroup.handleOpen(PackageExplorerActionGroup.java:373)
at
org.eclipse.jdt.internal.ui.packageview.PackageExplorerPart$ 4.open(PackageExplorerPart.java:526)
at
org.eclipse.ui.OpenAndLinkWithEditorHelper$InternalListener. open(OpenAndLinkWithEditorHelper.java:48)
at
org.eclipse.jface.viewers.StructuredViewer$2.run(StructuredV iewer.java:842)
at org.eclipse.core.runtime.Platform.run(Platform.java:888)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:48)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:17 5)
at
org.eclipse.jface.viewers.StructuredViewer.fireOpen(Structur edViewer.java:840)
at
org.eclipse.jface.viewers.StructuredViewer.handleOpen(Struct uredViewer.java:1101)
at
org.eclipse.jface.viewers.StructuredViewer$6.handleOpen(Stru cturedViewer.java:1205)
at org.eclipse.jface.util.OpenStrategy.fireOpenEvent(OpenStrate gy.java:264)
at org.eclipse.jface.util.OpenStrategy.access$2(OpenStrategy.ja va:258)
at org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrate gy.java:298)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1003)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3880)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3473)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2405)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2369)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 21)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:500)
at
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:332)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:493)
at
org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:113)
at
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:194)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:368)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at
at
at java.lang.reflect.Method.invoke(Method.java:592)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 559)
at org.eclipse.equinox.launcher.Main.main(Main.java:1287)
Re: generating bpmn_diagram from bpmn file or why did the semantic refresh fail? [message #528725 is a reply to message #528599] Wed, 21 April 2010 10:58 Go to previous messageGo to next message
Not sure what you did or what you mean by programmatic changes.
I would tend to think you should not do this kind of thing. When modifying the semantic model, think about the diagram model too.
Antoine
Re: generating bpmn_diagram from bpmn file or why did the semantic refresh fail? [message #528747 is a reply to message #528725] Wed, 21 April 2010 11:54 Go to previous messageGo to next message
Hi Antoine,
changes based on the EMF reflective API
but why? The diagram is only another presentation for the underlying
model. A textual representation is possible for a bpmn model, too.
Ok, that's the part of my programmatic changes. But why does it not work
to instantiate the diagram from the core bpmn file?
best regards,
Jan
Re: generating bpmn_diagram from bpmn file or why did the semantic refresh fail? [message #528794 is a reply to message #528747] Wed, 21 April 2010 14:57 Go to previous messageGo to next message
It's possible that something is wrong with your semantic model. You should investigate that, note also that this is part of the GMF project, not the code of the BPMN modeler. That feature was never really reliable.
Antoine
Re: generating bpmn_diagram from bpmn file or why did the semantic refresh fail? [message #528870 is a reply to message #528794] Thu, 22 April 2010 05:00 Go to previous messageGo to next message
Hi Antoine,
What do you exactly mean with "semantic model"? I tell you how I tried
it out: First I started by creating a normal BPMN diagram. I have put my
tasks onto the canvas and drew the transitions. In parallel the bpmn
file, containing the underlying model, grows. After that, I deleted only
the bpmn_diagram file and right-clicked the bpmn file and invoked the
generation of the diagram. You see that the same model was created with
the diagram before. And after the creation I got the depicted errors and
exceptions.
Should I discuss this in the GMF group? I've never had problems of
generating a diagram from a model with other metamodels. So I thought I
could find help directly from those guys who had created and extended
the graphical editor.
best regards,
Jan
Re: generating bpmn_diagram from bpmn file or why did the semantic refresh fail? [message #528983 is a reply to message #528870] Thu, 22 April 2010 10:32 Go to previous message
Sure. We might have a bug opened for this as well.
Antoine
Previous Topic:How to get the Ecore metamodel for BPMN
Next Topic:Move to SOA TLP
Current Time: Fri Jul 18 20:06:20 EDT 2025
Powered by FUDForum. Page generated in 0.04991 seconds
