Home » Eclipse Projects » Remote Application Platform (RAP) » [Text widget][Context menu](Caret missing for the Text widget when the widget has attached a context menu.)
[Text widget][Context menu] [message #528581] Wed, 21 April 2010 03:37 Go to next message
I implemented an edit functionality (copy/cut/paste) from the context menu attached to a Text widget.
After any edit operation is performed using this context menu and the menu gets hidden, the Text widget has focus (at least the code check says so) but the caret and selection view is missing (it behaves like it doesn't have focus).
With RAP 1.2 it worked, but with RAP 1.3 not anymore.
Is this a known bug?
Thank you in advance,
Cristina
Re: [Text widget][Context menu] [message #528616 is a reply to message #528581] Wed, 21 April 2010 05:24 Go to previous messageGo to next message
Hello Cristina.
I get a similar behavior using the current CVS version. Could you file a
bugzilla entry with a code-snippet that recreates your scenario?
Greetings,
Tim
> Cristina
Re: [Text widget][Context menu] [message #528627 is a reply to message #528616] Wed, 21 April 2010 06:25 Go to previous messageGo to next message
Hello Tim,
Many thanks for your reply, I will report it.
Best Regards,
Cristina
Re: [Text widget][Context menu] [message #529008 is a reply to message #528627] Thu, 22 April 2010 11:46 Go to previous message
For the ones interested - this bug is fixed, target milestone RAP 1.3 M7 (4th of May).
Cristina
Previous Topic:RAP and E4 (SWT BE + Modeled Workbench)
Next Topic:Communication from RAP to JavaScript
Current Time: Fri Jul 18 18:55:22 EDT 2025
Powered by FUDForum. Page generated in 0.04577 seconds
