Home » Eclipse Projects » Plugin Development Environment (PDE) » Building an Eclipse Plugin (depending on another Eclipse Plugin) using Maven
Building an Eclipse Plugin (depending on another Eclipse Plugin) using Maven [message #528323] Tue, 20 April 2010 03:51 Go to next message
I am attempting to use Maven to build two Eclipse plug-ins, I am implementing an ODA driver and the UI for the BIRT reporting extension.
So my two plugins:
  • 1. The Driver plug-in
  • 2. The UI plug-in which depends on the Driver plug-in
I have setup both plug-ins' poms very similarly, the included Maven plugins that do the majority of the build stuff are listed below:
I am unsure how I specifiy that the Driver plug-in is needed by the UI plug-in. I have added the Drvier plug-in to the 'Require-Bundle' attribute of UI's manifest file which means that both plug-ins successfully build and work when tested in Eclipse, but when I perform 'mvn install' for the UI plug-in, I get loads of compile errors saying that any classes contained in the Driver plug-in cannot be found...
The Driver plug-in builds with no issues, so I thought that maybe I could add it to the list of dependencies for the UI plug-in (in the UI's POM), but if I do this, since packaging is zip I cannot add to the classpath like other dependencies. If I change the Driver's packaging to jar the Driver fails to build...I'm stuck!
Any ideas?
Thanks in advance.
Re: Building an Eclipse Plugin (depending on another Eclipse Plugin) using Maven [message #528353 is a reply to message #528323] Tue, 20 April 2010 04:49 Go to previous messageGo to next message
Tycho 0.8 with Maven 3 is what you need:
* http://www.eclipse.org/proposals/tycho/
* http://mattiasholmqvist.se/2010/02/building-with-tycho-part- 1-osgi-bundles/
* http://divby0.blogspot.com/2010/03/im-in-love-with-tycho-08- and-maven-3.html
Mickael Istria - BonitaSoft S.A.
http://www.bonitasoft.com/products/downloads.php
Re: Building an Eclipse Plugin (depending on another Eclipse Plugin) using Maven [message #528711 is a reply to message #528323] Wed, 21 April 2010 10:45 Go to previous messageGo to next message
If anyone's interested I managed to get it to work - a little bit hacky...
I added an ant task on the install phase of the Driver plug-in's build process, and that task simply copies the class files which are placed under: target/pdeTemp/plugins/${plugin-name}_${version}/@dot, into: target/classes.
Now it compiles!
Re: Building an Eclipse Plugin (depending on another Eclipse Plugin) using Maven [message #605629 is a reply to message #528323] Tue, 20 April 2010 04:49 Go to previous messageGo to next message
Re: Building an Eclipse Plugin (depending on another Eclipse Plugin) using Maven [message #605646 is a reply to message #528323] Wed, 21 April 2010 10:45 Go to previous message
Now it compiles!
Previous Topic:How to put a textbox in a toolbar of a view based plugin
Next Topic:using compare apis without the plugin environment
Current Time: Sun Jul 27 10:05:31 EDT 2025
Powered by FUDForum. Page generated in 0.03835 seconds
