Home » Eclipse Projects » Remote Application Platform (RAP) » User-Jobs cannot be rescheduled
User-Jobs cannot be rescheduled [message #528319] |
Tue, 20 April 2010 03:21  |
I face a severe problem with the Jobs API. The code below works in RCP, but
not in RAP. So I guess there's something odd in the RAP implementation.
The snippet blow fills a table as a result of a job execution. If the job is
scheduled the first time everything is fine. If the job is scheduled anew a
JobCanceler is notified which calls the done-Method with a Cancel Status and
the job is not executed.
This is a User job. In the ApplicationWorkbenchWindowAdvisor I set
public void preWindowOpen() {
IWorkbenchWindowConfigurer configurer = getWindowConfigurer();
configurer.setShowProgressIndicator( true );
to see the ProgressIndicator and I also call job.setUser(true) before
scheduling, what might cause the problem. Because, if I do not set the job
as Userjob, the job handling works the way it should.
Snippet:
public void createPartControl(Composite parent) {
Link l = new Link(parent, SWT.NONE);
l.setText("<a>start</a>");
final TableViewer v = new TableViewer(parent, SWT.BORDER);
v.getControl().setLayoutData(new GridData(SWT.FILL, SWT.FILL, true,
true));
v.setLabelProvider(new LabelProvider() {
/** {@inheritDoc} */
public String getText(Object element) {
return element.toString();
v.setContentProvider(new ArrayContentProvider());
final Job job = new Job("loading") {
protected IStatus run(IProgressMonitor monitor) {
elements = new String[100];
for (int i=0;i<100;i++) {
elements[i] = "Element " + i;
try {
Thread.currentThread().sleep(10);
} catch (InterruptedException e) {
e.printStackTrace();
return Status.OK_STATUS;
job.setUser(true);
job.setPriority(Job.SHORT);
job.addJobChangeListener(new JobChangeAdapter() {
public void done(IJobChangeEvent event) {
if (event.getResult().getSeverity() == Status.CANCEL) {
System.out.println("Cancel????");
return;
v.getControl().getDisplay().asyncExec(new Runnable() {
public void run() {
v.setInput(elements);
l.addSelectionListener(new SelectionAdapter() {
public void widgetSelected(SelectionEvent e) {
job.schedule();
GridLayoutFactory.swtDefaults().generateLayout(parent);
Help - I need somebody - Help - not just anybody...
Thanks, Niels
Re: User-Jobs cannot be rescheduled [message #528332 is a reply to message #528319] |
Tue, 20 April 2010 04:01   |
Hi Niels,
maybe you run into this bug:
274806: Job with display.(a)syncExec do not update UI/Table properly
https://bugs.eclipse.org/bugs/show_bug.cgi?id=274806
Best,
Ivan
On 04/20/2010 10:21 AM, Niels Lippke wrote:
> RCP, but not in RAP. So I guess there's something odd in the RAP
> implementation.
> job is scheduled the first time everything is fine. If the job is
> scheduled anew a JobCanceler is notified which calls the done-Method
> with a Cancel Status and the job is not executed.
> job as Userjob, the job handling works the way it should.
> Snippet:
> true));
> @Override
> @Override
> try {
> job.setUser(true);
> @Override
> return;
> @Override
> public void run() {
> @Override
> job.schedule();
> Thanks, Niels
Re: User-Jobs cannot be rescheduled [message #528346 is a reply to message #528332] |
Tue, 20 April 2010 04:23   |
I don't think so. My UI is updated perfectly.
My problem is, that the job's run()-Method is not called on subsequent
schedules. Adding a UICallback brings nothing.
Regards, Niels
"Ivan Furnadjiev" <ivan@eclipsesource.com> schrieb im Newsbeitrag
news:hqjn04$iug$2@build.eclipse.org...
> Hi Niels,
> Best,
> Ivan
>> Hi,
>> implementation.
>> is scheduled the first time everything is fine. If the job is scheduled
>> anew a JobCanceler is notified which calls the done-Method with a Cancel
>> Snippet:
>> true));
>> @Override
>> @Override
>> try {
>> job.setUser(true);
>> @Override
>> return;
>> @Override
>> public void run() {
>> @Override
>> job.schedule();
>> Thanks, Niels
Re: User-Jobs cannot be rescheduled [message #528348 is a reply to message #528346] |
Tue, 20 April 2010 04:27   |
Nies,
you mean that manually activating of the callback before the first job
execution does not solve the problem?
Best,
Ivan
> Regards, Niels
>> Hi Niels,
>> Best,
>> Ivan
>>> Hi,
>>> implementation.
>>> the job is scheduled the first time everything is fine. If the job
>>> is scheduled anew a JobCanceler is notified which calls the
>>> done-Method with a Cancel Status and the job is not executed.
>>> before scheduling, what might cause the problem. Because, if I do
>>> not set the job as Userjob, the job handling works the way it should.
>>> Snippet:
>>> true));
>>> @Override
>>> @Override
>>> try {
>>> job.setUser(true);
>>> @Override
>>> return;
>>> @Override
>>> public void run() {
>>> @Override
>>> job.schedule();
>>> Thanks, Niels
Re: User-Jobs cannot be rescheduled [message #528349 is a reply to message #528348] |
Tue, 20 April 2010 04:41   |
Yes - I mean No it does not solve the problem.
Niels
news:hqjohv$ob9$1@build.eclipse.org...
> Nies,
> Best,
> Ivan
>> Regards, Niels
>>> Hi Niels,
>>> Best,
>>> Ivan
>>>> Hi,
>>>> implementation.
>>>> Snippet:
>>>> true));
>>>> @Override
>>>> @Override
>>>> try {
>>>> job.setUser(true);
>>>> @Override
>>>> return;
>>>> @Override
>>>> public void run() {
>>>> @Override
>>>> job.schedule();
>>>> Thanks, Niels
Re: User-Jobs cannot be rescheduled [message #528357 is a reply to message #528349] |
Tue, 20 April 2010 05:05   |
In this case, if your code works in RCP, feel free to open a bugzilla
with the attached snippet to reproduce it.
TIA,
Ivan
> Regards,
> Niels
>> Nies,
>> job execution does not solve the problem?
>> Best,
>> Ivan
>>> subsequent schedules. Adding a UICallback brings nothing.
>>> Regards, Niels
>>>> Hi Niels,
>>>> Best,
>>>> Ivan
>>>>> Hi,
>>>>> implementation.
>>>>> Snippet:
>>>>> true, true));
>>>>> @Override
>>>>> @Override
>>>>> try {
>>>>> job.setUser(true);
>>>>> @Override
>>>>> return;
>>>>> @Override
>>>>> public void run() {
>>>>> @Override
>>>>> job.schedule();
>>>>> Thanks, Niels
Re: User-Jobs cannot be rescheduled [message #528381 is a reply to message #528357] |
Tue, 20 April 2010 06:18  |
Done. Bug #309786
Thanks, Niels
news:hqjqpn$6gi$1@build.eclipse.org...
> In this case, if your code works in RCP, feel free to open a bugzilla with
> TIA,
> Ivan
>> Regards,
>> Niels
>>> Nies,
>>> Best,
>>> Ivan
>>>> Regards, Niels
>>>>> Hi Niels,
>>>>> Best,
>>>>> Ivan
>>>>>> Hi,
>>>>>> implementation.
>>>>>> Snippet:
>>>>>> true));
>>>>>> @Override
>>>>>> @Override
>>>>>> try {
>>>>>> job.setUser(true);
>>>>>> @Override
>>>>>> return;
>>>>>> @Override
>>>>>> public void run() {
>>>>>> @Override
>>>>>> job.schedule();
>>>>>> Thanks, Niels
Current Time: Thu Sep 18 10:49:05 EDT 2025
Powered by FUDForum. Page generated in 0.15618 seconds
